16771 Discussions
Running 'Intel® Driver & Support Assistant' fails with message 'Scan Error'
JohnPFW
The detail of the Scan Failure message says:
"Failed to scan system for updates. Please click "Refresh Results" to try again."
I have tried running it using Chrome, Firefox and Edge - same result.
Uninstalled the app and installed a fresh copy from intel website - same error.
Confirmed the services related to the assistant are running.
I have a 2nd identical server which is having the same problem.
Screenshot of error attached.
Results of System Support Utility scan attached.
Any help will be very much appreciated.
Hugo_Intel
Hello JohnPFW
Thank you for posting on the Intel Communities. I am sorry you are experiencing issues when trying to use Intel® Driver & Support Assistant on your system,
Based on the log files that you provided you are using an Intel® Server and Windows Server 2012, the hardware as well as the Operating System are not supported by the Intel® Driver & Support Assistant, and drivers are not provided for these products through this tool. Our recommendation is to use the Download Center to update your drivers.
Please check the following article for more information:
Intel Products That Aren’t Supported by Intel® Driver & Support Assistant (Intel® DSA)
Common Reasons why the Intel® Driver & Support Assistant (Intel® DSA) isn't Finding your Hardware
Intel® Driver & Support Assistant Fundamentals
Hugo O.
Hugo_Intel
Hello JohnPFW
Hugo O.
Hugo_Intel
Hello JohnPFW
I hope you are doing fine.
Hugo O.
Hugo_Intel
Hello JohnPFW
We're glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Hugo O.
