連結已複製
Hello WLip0,
Thank you for posting on the Intel ® communities.
I have found some information which describes how the Socket LGA-1150 works. Please refer to the link below:
I hope this helps.
David V
A Contingent Worker at Intel
Hello WLip0,
Thank you for your response.
If you are a designer then I would recommend you to register in our resource & design center website and once your account has been approved you will have access to other technical specifications. If available, the information should be there.
https://www.intel.com/content/www/us/en/design/resource-design-center.html
If you are not a designer, then to give you other options, you can try contacting an Authorized distributor and request a FAE (Field Application Engineer) so he can provide you with more information about it. You can also try contacting your motherboard manufacturer to see if they can disclose the information of the socket they have integrated.
Finally, try posting the question in our embedded community for more information and/or assistance. Refer to the link below:
https://forums.intel.com/s/topic/0TO0P00000018NGWAY/embedded-intel-core
I hope this helps.
David V
