16785 ディスカッション
Strange CPU, Battery and Power Adapter Behaviour
LJack4
ビギナー
1,785件の閲覧回数
I have only recently began to monitor my computer's performance so bear with me if my questions are a bit stupid.
First, the specs:
Acer Aspire V3-572G Laptop
Windows 10
Intel Core i7-5500U CPU @2.40Ghz (Turbo Boost to 3.0Ghz)
8 GB of DDR3 Ram
1000GB HDD
And these are my 3 problems:
Problem 1
No battery, only connected to power adapter.
Even when the computer is completely idle, power limit throttling is constantly on 100%. Does the software or sensor get confused?
Problem 2
The clock speed can't go above 2.40Ghz, in spite of the fact that it is on high performance mode. This problem goes away when the battery is put back in.
Problem 3
Battery inserted and connected to power adapter.
When I run performance tests such as Cinebench and prime95, power limit throttling almost immediately kicks in. I've noticed that it quickly reaches 15W which is my TDP. The CPU temperature is on average 83 degrees for core 1 and 84 degrees for core 2. Also, the core speed stays under 2.40Ghz for these tests (please see the screenshot below). Is it safe to raise the Watts limit and will this increase performance?
Thanks for looking into my problems. I look forward to hearing back from you.
0 件の賞賛
1 返信
Allan_J_Intel1
従業員
934件の閲覧回数
The Intel(R) XTU was designed for overclocking and it might not be totally compatible with your laptop computer. You may want to try monitoring software provided by http://www.acer.com/ac/en/US/content/support Service & Support | Acer Official Site
Try running the Intel(R) Processor diagnostic tool and check if there is something wrong on the processor side.
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool-64-bit- Download Intel® Processor Diagnostic Tool (64-bit)
Allan.
返信
