- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Replaced every single system part of mine, after endless amount of time trying to pin point the issue I just cant.
Things i've tried:
1. Reinstalling the os, secure erasing ssd's, clearing the CMOS, updating bios / uefi firmware, changing motherboards.
2. Disconnecting everything from the system, clean driver installs, checking temps, monitoring the system etc, checking for malware, you name it.
Strange things that i've noticed so far:
When using my browser in the background and playing a video, which is >60 fps, that is - 120 fps, the cpu randomly jumps to 100% usage on almost every core but it is not persistent?
Having apps open in the background like Discord, Steam, Browser or anything of that sort makes games lock up?
Playing video in the background (locally) through a video player and recording the game with obs studio with x264 encoding probably doesnt make the game lock up as much but i'm not too sure.
Should the 6600k / 10700k's be brought to their knees when lightly multi tasking? The only part that I haven't truly replaced was my PSU.
I've ordered an i3 10105F for troubleshooting purposes and yet to order a different power supply.
Also my cpu might have suffered from heat damage it seems? I'll attach a picture below:
Really, my system can't do any kind of real time scheduling tasks or anything related to that.
What would be the best way to troubleshoot this kind of issue if it's even related to the CPU?
Thanks, Syntractrix.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
You did not name the motherboards you are using.
And, what anti-virus product are you using?
What OS are you using?
Provide more detail. Since you have tried two different processors, you should not be blaming the processors.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Current motherboard: Asus z170 pro gaming
Current processor: 6600k
Up to date motherboards: z490 msi unify, gigabyte aorus master.
Antivirus: Windows defender (currently disabled), malwarebytes (uninstalled) since both found nothing I've reinstalled the operating system multiple of times there should be no software malware. Anyways, highly doubt its malware.
OS: W10 21H2 19044.1826 (fully updated)
Anyways, as you've said that I should not be blaming the processors, but they do spike to 100% (at least the 6600k does) doesn't the problem point to the cpu kind of? Maybe this is the wrong forum to post in, but nobody has yet solved this issue.
Providing more information: When recording with NVENC encoder the stutters do happen, but they're impossible to notice on my side? With a 3000 series graphics card that is, I havent checked it they stop showing up on my side with 1000 series GPU when recording that is.
CPU Is running at completely stock settings, Turbo boost disabled 3.5/3.3ghz
Ram: Jedec settings, with XMP disabled: 2133mhz
Attaching some frametime graphs below:
When the stutters happen: https://imgur.com/a/91hrkSK
When the system is running without anything open in the background with enlarged graph: https://imgur.com/a/TQuxLvV
Also, I realize that these may not the appropriate forums to post in, sorry!
Syntractrix.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
For some reason, my last reply didn't send itself, and there was no saved state. I'll be sending a shortened message instead.
(Posting for 3rd time, all of my replies disappeared so I won't be using the reply to user function)
Current motherboard: Asus Z170 pro gaming
Up to date motherboards: Z490 gigabyte aorus master, msi unify.
Also the processors, at least the 6600k spike to 100% usage while doing these activities, so that's why I was pointing to the CPU.
CPU is running at stock speeds, turbo boost disabled 3.5/3.3ghz
Ram: JEDEC settings 2133mhz XMP disabled
Example of stutters happening in game: https://imgur.com/a/TKm80A7
Example of the frametime graph when nothing is running in the background: https://imgur.com/a/eh5i5gv
When I record with NVENC encoder (3000 series) instead of x264 the stutters happen in-game but they don't appear on my side, which is weird to me. Did not test if its the same case with my 1000 series card.
Also, I realize these may not be appropriate forums to post in. Sorry!
Syntractrix.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
(Posting for 3rd or 4th time now, hopefully it goes through, something weird is happening.)
Up to date motherboards: z490 gigabyte aorus master, msi unify.
Example of the frametime graph when nothing is running in the background last pic is enlarged:
When I record with NVENC encoder (3000 series) instead of x264 encoder the stutters happen in-game but they don't appear on my side, which is weird to me. Did not test if its the same case with my 1000 series card.
Syntractrix.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Syntractrix,
If I mat jump into the conversation and to have a better understanding of your issue, please provide me with the following:
When did the issue start?
You mentioned 6600k spikes to the 100% workload. Do you experience the same behavior with the 10700k?
You also stated that the game locks up when you Play video and record the game. Do you suffer the same lockup issue when you only run the game? Could you try to replicate it when recording into a lower resolution, or only play the video while playing the game?
Again, you expressed that the stutters happen in-game, but it doesn't appear on your side. Could you explain in more detail what you mean? Does the stutter only appear on the recording?
What is the name of the games you are having issues with?
Create a report using the Intel
• Download the Intel SSU (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html)
• Open the application and click on "Scan" to see the system and device information. By default, Intel
• To save your scan: click on "Next"; then "Save."
Also, if you want to test your CPUs, you can try and run the Intel® Processor Diagnostic Tool. (Intel
• Once installed, the Intel® PDT starts testing the processor using the default configuration. Two windows might appear to show the test is in progress.
• When the Intel® PDT completes, the testing status will display either a PASS or FAIL.
Alternatively, you can open or save the test results file every time after the test run by clicking on file > view results file, file, then, save as to any location you specify.
Jean O.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Syntractrix,
I hope you are doing fine.
Jean O.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Syntractrix,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
