16777 Discussions
TPM Admin not recognizing Intel Platform Trust Technology
ScottS
Although I have re-enabled Intel PTT in the bios after a bios update, TPM Admin still is not recognizing the PTT.  Am I missing a step to get it recognized?
Alberto_R_Intel
ScottS, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this topic, we just wanted to confirm a few details about your system:
What is the model of the Intel® Processor?
What is the model of the motherboard?
If this is a laptop, what is the model of it?
Is this a new computer?
Was it working fine before?
Did you make any recent hardware/software changes besides the BIOS update?
Which Windows* version are you using?
Please attach the SSU report so we can verify further details about the components in your platform, please check all the options in the report including the one that says "3rd party software logs":
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
ScottS
System was running 100% fine and TPM recognized the Intel PTT prior to bios update. Please responses below...
i7-8700
GIGABYTE Z370 HD3P
N/A
No
Yes; prior to the bios update
WIFI adapter, but had no adverse affect on the PC
Windows 10 x64 Pro
Home
Alberto_R_Intel
ScottS, Thank you very much for providing that information and the SSU report.
According to the SSU report, the BIOS version currently installed is the latest one which is F14b.
So, since the problem started right after the BIOS update and everything related to the BIOS was designed and customized by Gigabyte, for testing purposes, we recommend to get in contact directly with them so they can provide further assistance on this topic and confirm if it is safe to do a rollback on the BIOS to the previous version that used to work fine and to gather the instructions on how to do that, they might have additional details if there might be a known issue with BIOS version F14b:
https://www.gigabyte.com/Support
https://www.gigabyte.com/Motherboard/Z370-HD3P-rev-10/support#support-dl-bios
Once you get the chance, please let us know the results so if necessary, we can further assist you.
Albert R.
ScottS
What did you need all that info for? I had already mentioned this occurred after a bios update.  Why do all component manufacturers try to pass the buck on to each other; it's a circle jerk.
Alberto_R_Intel
Hi ScottS, Thank you very much for your response.
Before we can recommend any type of suggestions on different subjects, we need to make sure first which is the platform being used.
For example, if you were using an Intel® NUC, that is an Intel® product, so we do support the BIOS on that specific device in the event there are any problems with it, in this case, the product you are working with is a Gigabyte board and they will be the ones that will further assist you with any kind of BIOS issues.
Albert R.
