16771 Discusiones
TUF Z690-PLUS D4 + i5 12400F NO VIDEO
Emba1xador
Principiante
9.239 Vistas
I bought an i5 12400f processor and a tuf gaming z690-plus d4 motherboard, and when I tried to turn on the pc, it didn't display a video, I contacted the store/manufacturer and exchanged both components for new ones, and still no giving video, I saw in some forum a person with a similar problem that had been solved by buying another processor (Celeron G6900) with this one I got the video, I updated the bios and when I switched to 12400f it still does not show video. I don't know what to do anymore, can someone help me?
COMPLETE SETUP:
Processor: i5 12400F
Motherboard: TUF Gaming z690-plis d4
Source: Sharkoon 750w 80 plus gold
Video card: RTX 3080TI Galax
Memory: 2x Sticks 8gb 3200MHz
0 kudos
11 Respuestas
DeividA_Intel
Empleados
9.220 Vistas
Hello Emba1xador,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Core™ i5-12400F Processor.
Bear in mind that the "F" does not include integrated graphics built into the processor and will depend on the dedicated graphics card to display video.
However, in order to better assist you, please provide the following:
1. Do you get any LED coed from the motherboard when there is no video?
2. Is the video cable (HDMI, DP, DVI) connected to the motherboard or to the graphics card?
3. Is the GPU properly installed in your motherboard?
4. Have you checked this issue with the motherboard and GPU manufacturers?
Deivid A.
Emba1xador
Principiante
9.150 Vistas
1- Placa mãe Asus Z690 plus d4 não apresenta o vídeo, o led meio verde escrito BIOS fica ligado, quer dizer que o Pc está na tela da BIOS, porém não tá mostrando
2- Está conectado na placa de vídeo, já testei 3 placas de vídeo diferente nenhuma apresenta imagem e nos outros Pc elas estão funcionando
3- GPU instalada no slot 16x no principal da placa
4- Ambos já foram trocados uma vez, porém o problema persiste, aliás a placa mãe já é a terceira.
n_scott_pearson
Superusuario
9.202 Vistas
I also want to understand the last comment that you made in the other thread. You seem to be stating that, when you used the G6900 processor, graphics worked from a motherboard connector but did not work from a graphics card connector. Is that correct? Or did you only test this processor with the graphics card removed?
If you are saying that, with the G6900 installed, you could not get any output with the monitor connected to the graphics card, then this is consistent with the Core i5-12400f case and not necessarily an issue with processors at all. It could be a case of the graphics card simply not working properly at all.
The answers to Deivid's questions are important either way.
Emba1xador
Principiante
9.150 Vistas
Sim, acabei comprando o g6900 para testar, ele apresenta imagem e o Pc funciona perfeitamente quando o cabo de vídeo está ligado na placa mãe, quando coloco placa de vídeo, ele não funciona mais, para fazer ele apresentar vídeo entro na BIOS antes de colocar a placa de vídeo, mudo a opção de vídeo para PCI aí sim ele apresenta vídeo com a placa de vídeo, mas ele não mostra as telas de iniciação fica na tela preta, o teclado apaga e ele fica desse jeito por uns 2m e depois aparece a imagem do windows.
Steven_Intel
Moderador
9.161 Vistas
We would like to know if you were you able to check the previous post.
Steven G.
DeividA_Intel
Empleados
9.098 Vistas
Hello Emba1xador,
Thanks for the response. Before we continue further, I would like to confirm the following:
1. You mentioned that the GPUs worked on a different system, have you tested the Intel® Core™ i5-12400F Processor on any of those systems?
2. Have you updated your BIOS to the latest version (2204)?
Deivid A.
Emba1xador
Principiante
9.093 Vistas
1- Não, pois não tenho outra placa mãe socket lga 1700.
2- Sim, atualizei para última versão.
n_scott_pearson
Superusuario
9.085 Vistas
You say you changed the option to PCI. What was it set to before? Typically, you leave it set to Auto all the time. That way it works properly regardless of whether internal or add-in graphics.
DeividA_Intel
Empleados
9.058 Vistas
Hello Emba1xador,
Thank you for the information provided. I will proceed to check the issue internally and post back soon with more details.
Bear in mind that our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Deivid A.
DeividA_Intel
Empleados
9.033 Vistas
Hello Emba1xador,
Thanks for your patience. Based on the troubleshooting performed, I recommend you get in contact with us directly to check the RMA options available for you.
Feel free to use the link based on your location:
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
anushree01
Principiante
4.270 Vistas
It sounds like you've done a lot of troubleshooting already, but I understand how frustrating this must be. Since you've swapped components and successfully updated the BIOS with the Celeron G6900, it seems like the motherboard is functioning properly. However, since the i5 12400F still isn't displaying video, it could be a compatibility issue or a power delivery problem.
Here are a few things to try:
Clear CMOS: Sometimes, even after a BIOS update, clearing the CMOS can resolve lingering issues.
Check Power Connections: Ensure that all power connections (especially CPU power) are securely plugged in.
Test with One RAM Stick: Try booting with just one RAM stick to rule out memory issues.
Double-check the BIOS version: Ensure it's the correct version for supporting the i5 12400F.
If none of these work, there might be an issue with the CPU itself, or you may need a deeper look into the motherboard’s compatibility. It could help to consult your local tech shop or contact support again.
Hope this helps!
Responder
