16792 Discusiones
Termal Throttling question?
IntsSed
Principiante
7.505 Vistas
Is there problem with Thermal Throttling?
Should I have to worry? Look images below.
Dell G5 15 5587 (Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz 2.21 GHz, 64 bit,
Windows 10 Pro, 20H2, NVIDIA GeForce GTX 1060 with MaxQ design, Intel UHD Graphics 630)
Thanks!
Etiquetas (1)
0 kudos
1 Solución
Shivam_Shobhit
Nuevo Colaborador I
7.307 Vistas
Hello IntsSed ,
Your processor is alright as the T Junction temp. for your processor i.e. Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz 2.21 GHz is 100 deg C, As per yu ran the test results the max temp. which you got is 85 deg C. So there is no issue with your system.
Thanks for posting your query. Do write if any further help needed.
Also posting the link where you can check this: https://ark.intel.com/content/www/us/en/ark/products/134906/intel-core-i7-8750h-processor-9m-cache-up-to-4-10-ghz.html
Shivam_Shobhit
Ver la solución en mensaje original publicado
9 Respuestas
AlHill
Superusuario
7.494 Vistas
Your processor is not supported by XTU.
Undervolting has been disabled by Intel for security concerns.
IntsSed
Principiante
7.477 Vistas
Thanks, AlHill, for answer!
I just ask, what is Throttling peaks, need worry?
What Throttling did to system/hardware?
Victor_G_Intel
Empleados
7.461 Vistas
Hello IntsSed,
If you want to check if your processor is working correctly with a validated software please use our IPDT tool, if the results show passed, it means that the processor is working correctly and, in case that you are not experiencing any problems related to the use of the laptop you shouldn't worry about the message from the XTU since as it has been discussed before, that software is not compatible with your build; therefore, no changes should be performed with it. What we recommend will be to delete it from your system with the following instructions.
  1. Use the Windows* 10 Apps and Features.
  2. Search for Intel® Extreme Tuning Utility.
  3. Click uninstall.
  4. Open the Task Manager..
  5. Check under Processes for XtuService
  6. If found, click End Task.
Victor G.
IntsSed
Principiante
7.315 Vistas
Thanks for answer, Victor_G_Intel!
I have tested laptop with "Intel® Processor Diagnostic Tool"
There are  testing image & results below. For me looks ok?
--- IPDT64 - Revision: 4.1.5.37
--- IPDT64 - Start Time: 17.05.2021 15:10:31
CPU1
Genuine Intel CPU Test
Module Version: 1.0.19.64b.W
Start Time: Mon May 17 15:10:32 2021
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Mon May 17 15:10:32 2021
Total Time: in seconds: 0
CPU1
CPU Brand String Test
Module Version: 1.0.23.64b.W
Test Result - PASS
Expected: Intel(R) Core(TM) @
Detected: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
Intel(R) Core(TM) processor detected..!!..
CPU1
Cache Test
Module Version: 1.0.18.64b.W
Test Result - PASS
 --- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 9216
Cache Size Test Passed!!!
CPU1
MMXSSE Test
Module Version: 1.0.25.64b.W
Test Result - PASS
DetectUtils64 DLL Version - 1.1.3
 --- Determining MMX - SSE capabilities ---
..MMX is supported on this CPU..
..SSE is supported on this CPU..
..SSE2 is supported on this CPU..
..SSE3 is supported on this CPU..
..SSSE3 is supported on this CPU..
..SSE4.1 is supported on this CPU..
..SSE4.2 is supported on this CPU..
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
CPU1
IMC Test
Module Version: 1.0.20.64b.W
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 16.00GB
--- Subtest - Memory Size Test Passed!!!  ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 bytes
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!!  ---
Integrated Memory Controller Test Passed!!!
End Time: Mon May 17 15:10:33 2021
Total Time: in seconds: 1
CPU1
Parallel_PrimeNum Test
Module Version: 1.0.0.10
Start Time: 17.05.2021 15:10:33
Test Result - PASS
Module GraphicsW.exe Completed - Pass
Module Math_PrimeNum.exe Completed - Pass
GraphicsW Module Test
Module Version: 1.0.4.64b.W
Start Time: Mon May 17 15:10:33 2021
GraphicsW Module Test: PASS
End Time: Mon May 17 15:11:19 2021
Total Time: in seconds: 46
Prime Number Generation Test
AVX is supported in your OS
Max AVX supported = AVX2
Test Result - PASS
Operation Per Second: 70788
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Mon May 17 15:11:18 2021
Total Time: in seconds: 45
Parallel_PrimeNum
End Time: 17.05.2021 15:11:19
CPU1
Parallel_FP Test
Start Time: 17.05.2021 15:11:20
Test Result - PASS
Module AVX.exe Completed - Pass
Module Math_FP.exe Completed - Pass
Start Time: Mon May 17 15:11:20 2021
End Time: Mon May 17 15:12:05 2021
AVX Test
Module Version: 2.0.25.64b.W
Test Result - PASS
  --- CPU Features Detection ---
..AVX is supported by this CPU..
..AVX2 is supported by this CPU..
..AVX512BW is NOT supported by this CPU..
..AVX512CD is NOT supported by this CPU..
..AVX512DQ is NOT supported by this CPU..
..AVX512ER is NOT supported by this CPU..
..AVX512F is NOT supported by this CPU..
..AVX512IFMA52 is NOT supported by this CPU..
..AVX512PF is NOT supported by this CPU..
..AVX512VBMI is NOT supported by this CPU..
..AVX512VL is NOT supported by this CPU..
..AES is supported by this CPU..
..PCLMULQDQ is supported by this CPU..
..AVX is supported by this Operating System..
Most Advanced AVX Feature Detected.. AVX2
AVX2 Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
End Time: Mon May 17 15:12:06 2021
Floating Point Test
Module Version: 1.0.22.64b.W
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 0.39
Error: 0
--- Floating Point Test Passed!!!---
Parallel_FP
End Time: 17.05.2021 15:12:06
CPU1
Parallel_Math Test
Start Time: 17.05.2021 15:12:06
Test Result - PASS
Module FMA3.exe Completed - Pass
Start Time: Mon May 17 15:12:06 2021
End Time: Mon May 17 15:12:52 2021
Test Result - PASS
Operation Per Second: 48184
Error: 0
End Time: Mon May 17 15:12:51 2021
FMA3 Test
Test Result - PASS
..FMA3 is supported by this CPU..
..FMA3 is supported by this Operating System..
FMA3 Test Result --- PASS
Parallel_Math
End Time: 17.05.2021 15:12:52
CPU1
Parallel_GPUStressW Test
Start Time: 17.05.2021 15:12:53
Test Result - PASS
Module GPUStressW.exe Completed - Pass
GPUStressW Module Test
Module Version: 1.0.15.64b.W
Start Time: Mon May 17 15:12:53 2021
GPUStressW Module Test: PASS
End Time: Mon May 17 15:13:23 2021
Total Time: in seconds: 30
AVX Test
Test Result - PASS
End Time: Mon May 17 15:13:26 2021
Total Time: in seconds: 33
FMA3 Test
Test Result - PASS
End Time: Mon May 17 15:13:24 2021
Total Time: in seconds: 31
Parallel_GPUStressW
End Time: 17.05.2021 15:13:26
CPU1
DGEMM Stress Test
Module Version: 1.0.11.64b.W
Start Time: Mon May 17 15:13:26 2021
Test Result - PASS
DGEMM AVX2 Test Result --- PASS
End Time: Mon May 17 15:14:26 2021
Total Time: in seconds: 60
CPU1
Frequency Check
Module Version: 1.0.3.64b.W
Start Time: Mon May 17 15:14:26 2021
Test Result - PASS
Processor Name: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
Expected Processor Frequency: 2.20
Measured Processor Frequency: 2.206627
End Time: Mon May 17 15:14:27 2021
System Information
Processor Information: Family 6 Model 9E Stepping A
Number of Physical Cores: 6
Number of Logical Cores: 12
Operating System: Microsoft Windows 10 Pro 64-bit
Graphics Information: Intel(R) UHD Graphics 630
--- IPDT64 - End Time: 17.05.2021 15:14:27
--- IPDT64 - Result: Pass
Victor_G_Intel
Empleados
7.434 Vistas
Hello IntsSed,
Please let me know if you need further assistance.
Victor G.
DeividA_Intel
Empleados
7.420 Vistas
Hello IntsSed,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
IntsSed
Principiante
7.403 Vistas
Thanks, Victor_G_Intel and DeividA_Intel, for response!
Sorry for delay! Last weeks i am so busy.
I have recieve Dell-Cares response and will try HWINFO - Hardware Information, Analysis, and Monitoring Tools.
I am interested also use XtuService and will respond.
Shivam_Shobhit
Nuevo Colaborador I
7.308 Vistas
Hello IntsSed ,
Shivam_Shobhit
IntsSed
Principiante
6.901 Vistas
Much, thanks, Shivam_Shobhit, for an encouraging answer!
I am not a technical person.
Still high temperature, for me :D, (look images below).
Have good day & thanks!
Responder
