16771 Discussions
The maximum number of socket for Xeon processor?
HyeongTak
Thanks for your help in advance.
AFAIK, Xeon Platinum line supports 8 sockets. However, I went over the url below :
https://ark.intel.com/content/www/us/en/ark/products/194146/intel-xeon-platinum-9282-processor-77m-cache-2-60-ghz.html
and it says max cpu configuration of Intel® Xeon® Platinum 9282 Processor is only "2".
What am I confusing with? Isn't the word "max cpu configuration" means the maximum number of socket that the cpu supports?
Also, is there any core-series processor comes with multi-socket support?
JoseH_Intel
Hello HyeongTak, We have confirmed that the Xeon Platinum 9200 processors such as the 9282, supports only two sockets. It is the Xeon Platinum 8200 processors that support 2, 4, or 8 sockets. So the information on ARK is correct. If you have further questions please let us know. Regards Jose A. Intel Customer Support Technician Under Contract to Intel Corporation
n_scott_pearson
The data in ARK may be wrong (it's happened before). Intel Customer Support will need to determine if this is the case and, if so, fix it.
As far as I know, the Core-branded processors support only single socket designs.
JoseH_Intel
Hello HyeongTak, Thank you for joining the community. We are confirming the information shown in ark. What we know is about a unreleased platform that will be 4 dual socket nodes that will support Xeon Platinum processors. So that could be the case for a dual socket maximum in a 8 socket combination. We will let you know when we have updates from engineering to clarify this. We appreciate your patience. Regards Jose A. Intel Customer Support Technician Under Contract to Intel Corporation
JoseH_Intel
