16794 Discussions
Turbo Boost not working: Intel Core i7-2670QM CPU @ 2.20GHz...
JVivi1
Game are running VERY slow, I ran the Intel processor diagnostic tool and it failed. See results here. --- Reading CPU Frequency --- Expected CPU Frequency is --> 2.20 Detected CPU Frequency is --> 0.80001 CPU Frequency Test Failed!!! --- Test End Time: 10/05/2014 20:17:18---. Looking for help. Thanks.
Full results attached.
Silvia_L_Intel1
Hello Jviv52, according to the test results you ran, the processor is not working as we expected.
Since this is an OEM system, it will be necessary to contact the system manufacture so they can help you with the replacement of the unit.
You can also check if you are running the latest BIOS version available for your system.
