TurboMood
StandaFac
Hello
It is possible to set the maximum processor performance in the Turbo Mood.
Intel Core i7 13700F
ASUS PRIME Z790 A WIFI
DeividA_Intel
Hello StandaFac,
This follow-up is to confirm if you have any additional questions related to Turbo boost or if the information provided was helpful.
Let me know if there are any other inquiries.
Deivid A.
DeividA_Intel
Hello StandaFac,
Thank you for posting on the Intel® communities. I understand you would like steps to set "TurboMood" to its maximum performance.
To be able to continue, I would like to confirm the following:
1. Just to confirm, by "TurboMood" do you mean "Tubo boost"?
2. Is "TurboMood" a BIOS setting or an operating system option?
3. Can you provide more details about this request?
4. What is the operating system installed as well as the version and build?
Deivid A.
StandaFac
I'm sorry I can't speak English.
Yes tuboboost.
On the contrary, I would like to reduce the maximum turboboost by about 20%.
windos 11 Home 22H2
Intel Core i7-13700F
ASUS PRIME Z790-A WIFI
ASUS DUAL GeForce RTX 4070 O12G
Kingston FURY 32GB KIT DDR5 6000MHz CL40 Beast White XMP
Kingston FURY Renegade NVMe 1TB
DeividA_Intel
Hello StandaFac,
Thanks for the confirmation. In this case, the turbo boost speed is controlled by the operating system, Windows will choose which core to increase the speed, for how long, and the moment to increase the CPU speed. There is no way to change the speed or set a specific value.
If you do not need or want this feature, you can disable it from the BIOS, I recommend you to check with Asus to confirm the steps in case you want to proceed.
You can check more details about this feature in the following article:
If you have any other questions, just let me know.
Deivid A.
DeividA_Intel
Hello StandaFac,
Deivid A.
DeividA_Intel
Hello StandaFac,
I was checking your thread and noticed that we have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
