- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
Hey Intel support.
I have Intel i7-12800hx with locked multiplier from the manufacture, please see the picture.
Please be careful! I don't need to overclock or under-voltage, I just need to underclock the multiplier using Intel XTU for full control of each core, except it is grayed out.
I can already underclock my CPU using power option > processor power management > maximum processor state, please see the picture
Except using this method, it will under clock all the core (p and e). I need to control each and every core separately.
Please allow to under clock CPU using XTU even if it locked for overclocking.
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello @jjp3
We understand you are experiencing limitations using the Intel® Extreme Tuning Utility, we will be more than happy to assist you.
Please answer the following:
· Was it working before?
· Have you contacted the System manufacturer to check for BIOS limitations?
Please check this Overclocking CPU with Intel® Extreme Tuning Utility, in the Advanced Tuning section, it explains how to modify the Processor Core Ratio individually.
If the issue persists, please check this:
· Make sure to have the latest BIOS version. Contact the System Manufacturer to get the latest BIOS and instructions to install it.
· Uninstall the Intel® XTU tool and reinstall it using the latest Intel® XTU version.
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello jjp3
We hope you are doing fine.
Were you able to check the previous questions?
Let us know if you updated the BIOS and reinstalled the Intel® XTU. If you still need assistance, please do not forget the report.
Jose B.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello jjp3
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
