16766 Discussions
Upgrade processor from Mobile Intel Celeron 530 1733 MHz
ОБори
I want to upgrade my laptop.
Now I have Mobile Intel Celeron 530 1733 MHz.
Motherboard FSB frequency - 533 MHz
Socket - mPGA479M
Which processors I can use for upgrading?
AlHill
You can only use processors that are socket, BIOS, and chipset compatible.
You need to contact the manufacturer of your laptop and ask them which processors are compatible with THEIR BIOS.
Then, you can select from those processors.
Doc
ОБори
Now it's impossible to contact with laptop manufacturer.
So I want to have list of processors according to Intel data.
AlHill
Which one of these processors do you have?
http://ark.intel.com/compare/29733,33100 ARK | Compare Intel® Products
I suspect this is your processor: http://ark.intel.com/products/29733/Intel-Celeron-M-Processor-530-1M-Cache-1_73-GHz-533-MHz-FSB-Socket-M Intel® Celeron® M Processor 530 (1M Cache, 1.73 GHz, 533 MHz FSB) Socket M Specifications
You will notice that it can use socket PPGA478 or PBGA479.
If it uses PPGA478, then here is a list of processors that use that socket:
http://ark.intel.com/Search/Advanced?s=t&SocketsSupported=PPGA478 ARK | Processor Feature Filter There are 199 processors from which to choose. However, it is extremely unlikely that your laptop manufacturer has support for all of those in their bios. This is why you need to contact the manufacturer. That, or take your chances, which could possibly damage your laptop.
If it uses PBGA479, then you have these processors: http://ark.intel.com/Search/Advanced?s=t&SocketsSupported=PBGA479 ARK | Processor Feature Filter
HOWEVER, there is nothing you can do as your processor is soldered to the motherboard.
Doc
ОБори
According to the processor label (SLA2G) - it is
Intel® Celeron® Processor 530
(1M Cache, 1.73 GHz, 533 MHz FSB) Socket P
According to http://ark.intel.com/products/33100/Intel-Celeron-Processor-530-1M-Cache-1_73-GHz-533-MHz-FSB-Socket-P Intel® Celeron® Processor 530 (1M Cache, 1.73 GHz, 533 MHz FSB) Socket P Specifications
sockets will be PGA478, PPGA478
But label at the socket is - mPGA479M
Program CPU-Z show that type of socket is mPGA479M
So I can't identify socket
AlHill
Then, feel free to use the http://ark.intel.com/Search/Advanced?s=t ARK | Processor Feature Filter , selecting the parameters you want until you satisfy yourself.
Still, I caution you on proceeding without knowing what processors your bios supports.
Doc
Hello felis_83 ,
I totally support the answers provided by Al.
Even if the socket is the same, the BIOS has to support it as well, this information is not available from our side since the OEM is the one that integrated/designed the laptop, for that reason is why we recommend contacting them directly to find what CPUs could work.
Hope you understand
Esteban C
