16772 討論
Upgrading to a Compatible CPU
DXue
初學者
3,058 檢視
Hi, I have a laptop mobile CPU I want to upgrade, but I just don't know which one works and compatible and which isn't.
I've taken the laptop apart before but the only problem is that I don't know what CPU would work on it and which socket it is.
My Specifications:
CPU: Intel Core i3 2370m
iGPU: Intel Graphic HD 3000
HDD: 500gb
RAM: 8gb (I installed 4gb extra myself).
My laptop is an Samsung NP300E5C-A07US
Also, the CPU isn't integrated onto the motherboard.
If you can also tell me what the package size is:
37.5mm x 37.5mm (rPGA988B); 31mm x 24mm (BGA1023)
I think one of them is integrated.
0 積分
5 回應
DXue
初學者
1,705 檢視
Also, can a third generation CPU like this work?
http://www.cpu-world.com/CPUs/Core_i7/Intel-Core%20i7-3612QM%20Mobile%20processor%20(AW8063801130504).html Core i7-3612QM
It uses a PGA socket.
I've found out it's 988B PGA
AlHill
超級使用者
1,705 檢視
This is your processor: http://ark.intel.com/products/53442/Intel-Core-i3-2370M-Processor-3M-Cache-2_40-GHz Intel® Core™ i3-2370M Processor (3M Cache, 2.40 GHz) Specifications
You must contact Samsung and ask them what processors are supported by their bios.
The processor must be both SOCKET and BIOS compatible.
Using a processor that is not supported by the Samsung bios may work, may work partially, may not work, and may even damage the motherboard.
Doc
員工
1,705 檢視
Hello, All:.
Brought, please refer to the previous post, All_Hill provided the correct answer.
Amy.
DXue
初學者
1,705 檢視
Thanks! I was able to get infomation from Samsung and found out some stuff.
Third Gen doesn't work.
Can only go up to 35 TDP
員工
1,705 檢視
That is good to hear! Thank you for sharing that info.
If you need further assistance let us know.
Amy.
回覆
