16765 Discussions
What is the main difference between a Server chipset and a Desktop chipset?
AGutm2
In particular, I'm talking about Q370 vs C246.
When building a system based on Intel Core processor, is there an advantage or disadvantage in using a server chipset?
AdrianM_Intel
Hello AGutm2,
The differences between both chipsets are in the following link:
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=133282,147326
In regards to the advantage or disadvantage, it depends on the purpose of your custom build.
Adrian M.
A Contingent Worker at Intel
n_scott_pearson
Here is a spec comparison: https://www.intel.com/content/www/us/en/products/compare-products.html/chipsets?productIds=147324,133293. As you can see, there are very few differences. What could be a factor is the capabilities of the motherboard itself. Server motherboards may sacrifice performance for stability.
AdrianM_Intel
Hello AGutm2,
Were you able to check our previous posts?
Let us know if you need more assistance.
Adrian M.
AdrianM_Intel
Hello AGutm2,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Adrian M.
