16771 Discussions
Where can i download the Intel IO Margin Tool(IOMT)
ashow
I want to download the IOMT tool for Intel Xeon eagle stream platform.But I can't search the tool location.
Allan_A_Intel
Hello, ashow,
Thank you for your patience. You need privileged RDC access. The information related to this tool can be found in there: https://www.intel.com/content/www/us/en/search.html?ws=idsa-default#q=Intel%C2%AE%20IO%20Margin%20Tool%20for%20Eagle%20Stream&sort=relevancy&f:@tabfilter=[Developers]
Allan
Allan_A_Intel
Hello, ashow,
Thank you for reaching Intel Communities. I will gladly help you.
Allow me to look into this to see if I can find the way to get that tool. I will contact you back as soon as possible.
Allan
Allan_A_Intel
Hello, ashow,
Allan
uriellua
Hi @Allan_A_Intel
I am also looking for the IOMT tool for Emeral Rapids CPU. Do you know where I can find that?
I am looking for the actual link since the search is not helping me find it.
Thank you,
Uriel
KCTSAI
Hi Allan,
想詢問 我在IOMT 上RUN SATA function ,僅僅只有得到Voltage Margin 卻未得到Timing Margin呢?
版本為715231_RPL_S_IOMT_1_0_14_1_PV_Release.zip.
請問是否在RPL_S 上 Timing Margin 已不重要?
Translated using ChatGPT
I would like to ask: when I run the SATA function on IOMT, I only get the Voltage Margin but not the Timing Margin.
The version I’m using is: 715231_RPL_S_IOMT_1_0_14_1_PV_Release.zip.
May I ask if Timing Margin is no longer important on RPL_S?
