16774 Discussões
Where is the download for Intel® Performance Maximizer for i5 9600k?
JayOC
Principiante
2.994 Visualizações
I see links for Core i9-9900K 9900KF 9900KS - v1.0.4.zip
and Core i5-9500K_F and Core i7-9700K_F - v1.0.4.zip
Where is i5 9600k?
It says that the download is valid for it, but where is the download? Neither of the two work for my CPU.
Here is the link for reference:
https://downloadcenter.intel.com/download/29435/Intel-Performance-Maximizer-for-9th-Generation-Intel-Core-Processors?product=188727
3 Respostas
AndrewG_Intel
Funcionário
2.979 Visualizações
Hello JayOC
As per the description on the download link below, the file "Core i5-9500K_F and Core i7-9700K_F - v1.0.4.zip" is the one recommended to install Intel® Performance Maximizer when using Intel® Core™ i5-9600K Processor:
  • "Another installer for i5-9600K, i5-9600KF, i7-9700K and i7-9700KF skus with the name “Core i5-9500K_F and Core i7-9700K_F - v1.0.4.zip”"
Please kindly refer to the Intel® Performance Maximizer User Guide for Minimum Requirements (Hardware and Software) and installation instructions:
https://downloadmirror.intel.com/29435/eng/Intel(R)_Performance_Maximizer_V1.0.4_User_Guide.pdf
Also, please review the Release Notes for known issues and workarounds. For instance, uninstall other overclocking applications before installing Intel® Performance Maximizer as they may interfere with this software:
https://downloadmirror.intel.com/29435/eng/Intel(R)_Performance_Maximizer_V1.0.4_Release_Notes.pdf
Once you have confirmed your system meets all the requirements, if you still have issues installing the software, please provide the following information?
1- Details and screenshots regarding the process that your are following and any error message.
2- Intel® System Support Utility (Intel® SSU) report to gather more details about your system.
  • Download the Intel® SSU and save the application on your computer: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
  • Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click Next and click Save.
Note: To upload and attach a file, use the "Drag and drop here or browse files to attach" dialog below the edit box.
Andrew G.
AndrewG_Intel
Funcionário
2.961 Visualizações
Hello JayOC
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back.
Andrew G.
AndrewG_Intel
Funcionário
2.950 Visualizações
Hello JayOC
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer being monitored.
Andrew G.
Responder
