16777 Discussions
Why does Intel's posted instructions yield this error when trying to add USB 3 drivers to my Windows 7 64 bootable USB.
User1583823435889111
Command line that ran is dism.exe /image:"C:\WIM\MOUNT" /Add-Driver /driver:"C:\WIM\USB30" /ForceUnsigned /recurse
Deployment Image Servicing and Management tool
Version: 6.1.7600.16385
Image Version: 6.1.7600.16385
Searching for driver packages to install...
Found 3 driver package(s) to install.
Installing 1 of 3 - C:\WIM\USB30\x64\iusb3hcs.inf: Error - An error occurred. The driver package could not be installed.
For more information, check for log files in the <windir>\inf folder of the target image.
Installing 2 of 3 - C:\WIM\USB30\x64\iusb3hub.inf: Error - An error occurred. The driver package could not be installed.
Installing 3 of 3 - C:\WIM\USB30\x64\iusb3xhc.inf: Error - An error occurred. The driver package could not be installed.
Error: 5
The command completed with errors. For more information, refer to the log file.
The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
The answer is the driver files in the temp working directory need to be unblocked by individually right clicking for properties and then doing so or with some special batch process something or another, this resulted in successful installation of the drivers onto the modified WIMs and stick thereafter.
AlHill
Wrong forum, and Windows 7 is dead.
Doc
