공지
16855 토론
Windows 10 BSOD - NMI_HARDWARE_FAILOUR Bugcheck Analysis says GenuineIntel.sys
Rony
초보자
21,961 조회수
Device: hp pavilion gaming 15 dk0132tx laptop
CPU: Intel Core i5 9300H @ 2.40GHz [Coffee Lake 14nm Technology]
Chipset: Intel® HM370
Graphics: Intel UHD Graphics 630
Wireless Adapter: Intel® Wireless-AC 9560 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 Combo
The Problem:
1.  Random Blue Screen Error when I use the laptop connected to the WIFI
2. The Blue Screen says NMI_HARDWARE_FAILOUR
2. The Error appears both in the working state and in the Idle state (Very randomly, 3-4 times a day)
3. No BSOD when using Ethernet / not connected to wifi
4. BSOD appear ONLY when I use wifi
Here are the Dump file Analysis Report of the last appeared BSOD Failure
* Bugcheck Analysis *
NMI_HARDWARE_FAILURE (80)
This is typically due to a hardware malfunction. The hardware supplier should
be called.
Arguments:
Arg1: 00000000004f4454, 'TDO'
Arg2: 0000000000000000, Status Byte
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 2015
Key : Analysis.DebugAnalysisProvider.CPP
Value: Create: 8007007e on HP-PAVILION-G15
Key : Analysis.DebugData
Value: CreateObject
Key : Analysis.DebugModel
Value: CreateObject
Key : Analysis.Elapsed.mSec
Value: 2039
Key : Analysis.Memory.CommitPeak.Mb
Value: 77
Key : Analysis.System
Value: CreateObject
ADDITIONAL_XML: 1
OS_BUILD_LAYERS: 1
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
BUGCHECK_CODE: 80
BUGCHECK_P1: 4f4454
BUGCHECK_P2: 0
BUGCHECK_P3: 0
BUGCHECK_P4: 0
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
STACK_TEXT:
ffffba01`638a2b58 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
MODULE_NAME: GenuineIntel
IMAGE_NAME: GenuineIntel.sys
STACK_COMMAND: .thread ; .cxr ; kb
FAILURE_BUCKET_ID: 0x80_4F4454_GenuineIntel_NOERRREC_IMAGE_GenuineIntel.sys
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {d5ef3836-2107-b7ec-b4d4-4d2ae9fc0e02}
Followup: MachineOwner
Crash Dump Analysis with WhoCrashed
On Sat 1/16/2021 8:07:19 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\011621-16546-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3F5780)
Bugcheck code: 0x80 (0x4F4454, 0x0, 0x0, 0x0)
Error: NMI_HARDWARE_FAILURE
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that a hardware malfunction has occurred.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
What can be the possible reason and solution for this problem?
I'd really appreciate your help regarding this problem.  Thanks!
0 포인트
1 솔루션
Sebastian_M_Intel
중재자
21,866 조회수
Hello Rony,
Thanks for the update.
In this case, the Linux installation confirms this is a hardware issue.
Unfortunately, there are no suggestions we can think of for this weird behavior. You should reach out to your OEM's support for additional assistance on this.
Sebastian M
Intel Customer Support Technician
원본 게시물의 솔루션 보기
10 응답
Sebastian_M_Intel
중재자
21,936 조회수
Hello Rony,
Thank you for posting on the Intel® communities.
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
  • Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
  • Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
2. Are you having issues with Wi-Fi, Bluetooth, or both?
3. Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
4. Were you able to have your wireless connection in a normal/expected performance before? If yes, did you make any changes before the issue started?
Sebastian M
0 포인트
Rony
초보자
21,929 조회수
Hello @Sebastian_M_Intel ,
I'm so glad you replied to me!
Here is the information you need:
1. The Intel® System Support Utility (Intel® SSU) is attached below.
2. I'm having issues mainly when connected to the Wi-Fi. I've tested both Bluetooth ON and OFF but the problem remains the same.
3.  YES, this the original adapter that came pre-installed with the system. I have not changed/installed a new adapter.
4.  I'm facing this problem since the second day of purchasing this laptop.
Additional Information to add:
1. I have tried to use a USB wifi adapter by disabling the integrated one from Windows Device Manager but the problem didn't go away.
2. Lastly I REMOVED the Original WIFI Card from my laptop and booted to windows without it. Attached a third-party USB WIFI dongle and use my laptop with it for around 2 hours then again the problem appeared!
What do you think can be the real cause of the problem? I'm afraid if it is not The Processor!!
I would really love to have a perfect solution from you.
Thanks & Best Regards
Rony
0 포인트
Sebastian_M_Intel
중재자
21,922 조회수
Hello Rony,
Thank you for your reply.
Based on what you are reporting, the problem does not seem to be related to your Intel wireless component.
Based on Microsoft's documentation, this problem can be caused by a variety of hardware malfunction and the exact cause is difficult to determine. https://docs.microsoft.com/en-us/windows-hardware/drivers/debugger/bug-check-0x80--nmi-hardware-failure#:~:text=The%20NMI_HARDWARE_FAILURE%20bug%20check%20has,a%20hardware%20malfunction%20has%20occurred.&text=This%20topic%20is%20for%20programmers,see%20Troubleshoot%20blue%20screen%20errors.
If you feel it may be the CPU, run the Intel® Processor Diagnostic Tool and send the results either in a screenshot or .txt file. To save the report, once the test is done, click on "File >> View Results File" and attach the .txt file to your reply.
In the end, my recommendations will be:
Sebastian M
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
0 포인트
Rony
초보자
21,913 조회수
Thanks for your messages and recommendations.
Therefore I request you to please check the attached CPU Test Results and let me know If the CPU has any problem or not.
Thanks again!
0 포인트
Sebastian_M_Intel
중재자
21,908 조회수
Hello Rony,
Thanks for the response.
Based on that report, the CPU seems to be running fine as it passed the tests.
Due to that, I strongly believe you have a problem with your OS, or you are facing hardware issues.
For either case you may follow our previous recommendations:
Sebastian M
0 포인트
Sebastian_M_Intel
중재자
21,877 조회수
Hello Rony,
Were you able to check the previous recommendations? Please let me know if you need more assistance.
Sebastian M
0 포인트
Rony
초보자
21,873 조회수
Sorry for the delayed response as I was testing the laptop by installing OS'es like Win 10 and Linux. Unfortunately, the result remains the same with no luck! You're right, the problem is not with software rather than the hardware.
After the extensive test performed the last couple of days I somehow manage to narrow down the problem actually. What I have figure out is, The BSOD NMI_HARDWARE_FAILOURE occurs every time I use my laptop WITHOUT THE ETHERNET connection. As long as the ethernet cable is plugged in there is no problem at all!
Do you have a suggestion for this problem?
Thank you very much for your cordial support from the beganing.
0 포인트
Myoben
초급자
18,749 조회수
Hi Ronny.
Did you eventually find a fix for this problem? I have the same laptop and also experience this issue from the second day after purchase too.
0 포인트
Sebastian_M_Intel
중재자
21,867 조회수
Hello Rony,
Sebastian M
Sebastian_M_Intel
중재자
21,850 조회수
Hello Rony,
I can see this post was marked as solved.
Based on that we will close it from our side, if you have any additional questions, please submit a new thread and we will gladly assist you.
Sebastian M
0 포인트
응답
