16803 讨论
XTU: Did VF-Curve feature get removed?
HumbleSquid
初学者
2,408 次查看
Installed the latest version of XTU software on 13900k, mobo is Asrock z790 Pro RS.  There is no VF-curve section in the tool. Not visible at all.  How do I view the VF-curve, and how do I modify it?
0 项奖励
4 回复数
Jean_Intel
员工
2,387 次查看
Hello HumbleSquid,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues with the Intel® XTU tool
For this issue, please try reinstalling the Intel® XTU, by following the steps listed below:
In case the issue is still present after reinstalling the tool, please provide me with the following:
  • A clear image of the Intel® and XTU showing what options are available. Especially the left menu where you can see the tabs for the system information, speed optimizer, advanced tuning, etc.
  • System report using the Intel System Support Utility (Intel SSU).
    • Download the Intel SSU.
    • Open the application and click "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
    • To save your scan, click "Next"; then "Save."
Jean O.
0 项奖励
AnaWilliam850
新分销商 I
1,716 次查看
thanks, I would try this, because I have a similar problem
0 项奖励
Jean_Intel
员工
2,356 次查看
Hello HumbleSquid
I hope you are doing fine.
Jean O.
0 项奖励
Jean_Intel
员工
1,722 次查看
Hello HumbleSquid,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
0 项奖励
回复
