16898 Discussions
XTU, Windows 11 and 13600K
SilvanoMattioli
when I start OC optimizzation on latest XTU (7.14.0.15) it say that 13600K is not supported as below.
All work fine until latest update.
teevee
Same for me
TurkaFroda
Same issue. Was working fine with i5-13600K before updating to 7.14.0.15. Tried updating bios. Turned off virtualization in BIOS. Tried with UVB protection Enabled, Disabled and Auto. OC is enabled in BIOS.
Full Specs:
IsaacQ_Intel
Hello SilvanoMattioli
1.      Were there any recent changes or updates to your Windows 11 operating system around the time you started experiencing the issue with XTU and the 13600K?
2.      Has XTU previously functioned properly with your 13600K?
Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
This document will be necessary to check your entire system, in order to find possible errors or incompatibilities.
Isaac Q.
teevee
1. The error only occurs when we update to the latest version of XTU.
2. Function well until the update
IsaacQ_Intel
 Thank you for responding. To proceed with our research, we need the SSU. Kindly furnish us with the necessary document.
Isaac Q.
IsaacQ_Intel
Hello SilvanoMattioli,
We hope you are doing fine.
Isaac Q.
IsaacQ_Intel
Best regards.
Isaac Q.
Nitay
I have the same thing with 13600k after updating to 7.14.1.12.
