- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
when I start OC optimizzation on latest XTU (7.14.0.15) it say that 13600K is not supported as below.
All work fine until latest update.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Same for me
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Same issue. Was working fine with i5-13600K before updating to 7.14.0.15. Tried updating bios. Turned off virtualization in BIOS. Tried with UVB protection Enabled, Disabled and Auto. OC is enabled in BIOS.
Full Specs:
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello SilvanoMattioli
1. Were there any recent changes or updates to your Windows 11 operating system around the time you started experiencing the issue with XTU and the 13600K?
2. Has XTU previously functioned properly with your 13600K?
Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
This document will be necessary to check your entire system, in order to find possible errors or incompatibilities.
Isaac Q.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
1. The error only occurs when we update to the latest version of XTU.
2. Function well until the update
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thank you for responding. To proceed with our research, we need the SSU. Kindly furnish us with the necessary document.
Isaac Q.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello SilvanoMattioli,
We hope you are doing fine.
Isaac Q.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Best regards.
Isaac Q.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
