16785 Discussions
XTU on Windows 11
rodrigoyasuda
So, I just upgraded to Windows 11, but started getting this error:
Unable to start Intel Extreme Tuning Utility. If there is another performance tuning application running, you must close it before trying to start this application.
I am using XTU 7.5.3.3, which supposedly supports Windows 11, according to XTU Download page (https://www.intel.com/content/www/us/en/download/17881/29183/intel-extreme-tuning-utility-intel-xtu.html)
I tried uninstalling/reinstalling it, and I also followed this tutorial to remove it completely but I still get the same error message: https://www.intel.com/content/www/us/en/support/articles/000032459/processors/processor-utilities-and-programs.html
Does anyone know how to fix this? It was working when I was on Windows 10.
Thanks in advance.
DeividA_Intel
Hello rodrigoyasuda,
Based on the information provide and the troubleshooting steps performed so far, the next thing to try would be a clean installation of the operating system.
Also, you can check with Microsoft first (since it was working with Windows 10) to confirm if there is any compatibility issue with some programs in the new Windows version.
Deivid A.
JeanSagi
Welcome to the real (Intel/Microsoft) world
Just kidding...
Maybe in some two to three years Intel/Microsoft will implement a fix for this...
In the mean time the only plausible solution I can think of is to downgrade to windows 10 and then XTU should run again.
Cheers!
J.
A55imilator
Actullay this is also broken in Win 10 if Hyper-V and / or core isolation is enabled.
JeanSagi
Well I had 7.5.3.3 working flawlessly on Windows 10 and just after upgrading to Windows 11 it automagically stopped working and I had Hyper-V installed and working because I could play backups create with Macrium Reflect.
Any of that is working now BTW...
J.
AndreyCh89
Dear Intel Support service, when will the problem you recognized be solved: "Core Isolation Memory Integrity, Hyper-V, and Virtual Machine State are incompatible with XTU. XTU is unable to function when these features are enabled."?
A55imilator
Intel need to work with Microsoft to fix this on our behalf, Intel need to make commitment to gamers that want to overclock can do so in a safe and secure way without compromising modern security practises.
