- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
Hi.
Hello. I left running Battlefield 5 in singleplayer campaign for hours,by standing in the same place in game. I go to sleep.
When i woke up i met desktop and Windows 10 message:"we've got an update for you"and it hangs because mouse cursor was a turning circle and unable to click anything,so i just ctrl alt delete and log out.
Event viewer said:"display driver stopped responding and has recovered".
This is exception code of crash:"0x887a0006 "according to MDMP WinDbG.
Also in background have only gpuz and msi afterburner + rivatuner.
My pc:9900K 4.7 stock
2x16GB DDR4 GSKILL 3000mhz XMP
Corsair 850 RmX
Rtx 2080 Ti Aorus Xtreme ( stock ,no oc )
I am using the newest drivers.
Also i tested Unigine Heaven ,3dmark firestrike and other games for hours and no crashes.
Memtest86 no errors. RAM TEST no errors. Realbench ok.
My question is that was related to hardware or maybe due that Windows update notification,or that doesnt matter? Also i cant reproduce this crash anymore. Some EA dude told me that is hardware crash. But i am not sure so i ask here.
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Newest drivers means nothing.
Confirm that you are using no intel graphics.
What operating system AND VERSION are you running? Be very specific.
Have you discussed this with your rtx manufacturer?
Have you run the https://downloadcenter.intel.com/download/19792
Doc
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I am using nvidia drive the newest. Win 10 1809 ver. Also it happened once after 14 hours being in game. Nothing more i am testing again and no crash.
CPu passing all stresstest and programs,apps. Ram the same.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
After 14 hours in the game, you probably crashed and just did not realize it.<G>
So, everything is ok, right?
Doc
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
now its fine but why it crashed/.?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
who knows? Could be the game, could be the OS...
Doc
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello.
I get 2 crashes in Battlefield 5 with exception 0x887a0006. Event viewer said: display driver recovery.
One time it crashed after 14 hours being in game,now it crashed after 2 minutes after started game.
And again its fine its running.
Corsair 850 RmX
I am using the newest drivers nvidia.
Is my hardware faulty?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hey. Its crash log. Can you analyze for me?:)
*** WARNING: Unable to verify timestamp for bfv.exe
*** WARNING: Unable to verify timestamp for dbdata.dll
KEY_VALUES_STRING: 1
Key : Analysis.CPU.Sec
Value: 2
Key : Analysis.Elapsed.Sec
Value: 10
Key : Analysis.Memory.CommitPeak.Mb
Value: 198
Key : Timeline.Process.Start.DeltaSec
Value: 373
PROCESSES_ANALYSIS: 1
SERVICE_ANALYSIS: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
Timeline: !analyze.Start
Time: 2019-06-25T15:22:01.435Z
Diff: 178818435 mSec
Timeline: Dump.Current
Time: 2019-06-23T13:41:43.0Z
Diff: 0 mSec
Timeline: Process.Start
Time: 2019-06-23T13:35:30.0Z
Diff: 373000 mSec
DUMP_CLASS: 2
DUMP_QUALIFIER: 400
MODLIST_WITH_TSCHKSUM_HASH: 5d4f03f892eff03a1c5435114ab49261724f087b
MODLIST_SHA1_HASH: f64fcc738ab2590fc75d22b7abdd1329c1d0ce06
COMMENT: Frostbite MiniDump. Address: 00007FFE80B39129 (In Windbg type: .ecxr)
[EOF]
NTGLOBALFLAG: 0
PROCESS_BAM_CURRENT_THROTTLED: 0
PROCESS_BAM_PREVIOUS_THROTTLED: 0
DUMP_FLAGS: a2
DUMP_TYPE: 11
CONTEXT: (.ecxr)
rax=00000000887a0006 rbx=000000003824ac40 rcx=000000003490bf38
rdx=0000000141ff1718 rsi=00000000887a0006 rdi=0000000000000000
rip=00007ffe80b39129 rsp=000000003490c6a0 rbp=000000003490c880
r8=0000000000000000 r9=000000003490bf3a r10=000000003490c059
r11=000000003490c337 r12=000000003825e460 r13=0000000038247dd0
r14=0000000038247dd0 r15=0000000143b9a7e8
iopl=0 nv up ei pl nz na po nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00000206
KERNELBASE!RaiseException+0x69:
00007ffe`80b39129 0f1f440000 nop dword ptr [rax+rax]
Resetting default scope
FAULTING_IP:
KERNELBASE!RaiseException+69
EXCEPTION_RECORD: 000000003490d290 -- (.exr 0x3490d290)
ExceptionAddress: 0000000000000000
ExceptionCode: 00000000
ExceptionFlags: 00000000
NumberParameters: 1285050106
Parameter[0]: 000073fd8db5e4c0
Parameter[1]: 0000000000000000
Parameter[2]: 00009ffd0010004f
Parameter[3]: 0053002b002b0033
Parameter[4]: 00000206002b002b
Parameter[5]: 00007ffe4c8681a5
Parameter[6]: 000000005bc926e0
Parameter[7]: 000000003490d410
Parameter[8]: 000000003490e170
Parameter[9]: 0000000000000000
Parameter[10]: 000000005bc926e8
Parameter[11]: 000000005be906e0
Parameter[12]: 000000005be90678
Parameter[13]: 0000000000001000
Parameter[14]: 00000000887a0006
DEFAULT_BUCKET_ID: APPLICATION_FAULT
PROCESS_NAME: bfv.exe
ERROR_CODE: (NTSTATUS) 0x887a0006 - Jednostka GPU nie odpowie na wi cej polece prawdopodobnie z powodu nieprawid owego polecenia przekazanego przez aplikacj wywo uj c .
EXCEPTION_CODE: (HRESULT) 0x887a0006 (2289696774) - The GPU will not respond to more commands probably due to an incorrect command given by the calling application.
EXCEPTION_CODE_STR: 887a0006
WATSON_BKT_PROCSTAMP: 5089d1b5
WATSON_BKT_MODULE: KERNELBASE.dll
WATSON_BKT_MODSTAMP: aee8f822
WATSON_BKT_MODOFFSET: 39129
WATSON_BKT_MODVER: 6.2.17763.592
MODULE_VER_PRODUCT: Microsoft® Windows® Operating System
BUILD_VERSION_STRING: 17763.1.amd64fre.rs5_release.180914-1434
ANALYSIS_SESSION_HOST: DESKTOP-RVP2EUM
ANALYSIS_SESSION_TIME: 06-25-2019 17:22:01.0435
ANALYSIS_VERSION: 10.0.18869.1002 amd64fre
THREAD_ATTRIBUTES:
OS_LOCALE: PLK
BUGCHECK_STR: APPLICATION_FAULT
PRIMARY_PROBLEM_CLASS: APPLICATION_FAULT
PROBLEM_CLASSES:
Type: [APPLICATION_FAULT]
Class: Primary
Scope: DEFAULT_BUCKET_ID (Failure Bucket ID prefix)
BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [Unspecified]
Frame: [0]
LAST_CONTROL_TRANSFER: from 0000000000000000 to 0ffda817418d0000
IP_ON_HEAP: 0ffda817418d0000
The fault address in not in any loaded module, please check your build's rebase
log at <releasedir>\bin\build_logs\timebuild\ntrebase.l og for module which may
contain the address if it were loaded.
UNALIGNED_STACK_POINTER: 000003e6830f02fd
STACK_TEXT:
00000000`3490c6a0 00000001`41ff1405 : 00000000`38247dd0 00000000`3824ac40 00000000`3490c880 00000000`887a0006 : KERNELBASE!RaiseException+0x69
00000000`3490c808 6e6f7361`65526465 : 64656c69`61662022 58442068`74697720 524f5252`455f4947 5f454349`5645445f : 0x766f6d65`52656369
00000000`3490c810 64656c69`61662022 : 58442068`74697720 524f5252`455f4947 5f454349`5645445f 0000202e`474e5548 : 0x6e6f7361`65526465
00000000`3490c818 58442068`74697720 : 524f5252`455f4947 5f454349`5645445f 0000202e`474e5548 00007ffe`83c25bd0 : 0x64656c69`61662022
00000000`3490c820 524f5252`455f4947 : 5f454349`5645445f 0000202e`474e5548 00007ffe`83c25bd0 00000000`0003ffff : 0x58442068`74697720
00000000`3490c828 5f454349`5645445f : 0000202e`474e5548 00007ffe`83c25bd0 00000000`0003ffff 00000000`3490c930 : 0x524f5252`455f4947
00000000`3490c830 0000202e`474e5548 : 00007ffe`83c25bd0 00000000`0003ffff 00000000`3490c930 000004e8`fffffb30 : 0x5f454349`5645445f
00000000`3490c838 00007ffe`83c25bd0 : 00000000`0003ffff 00000000`3490c930 000004e8`fffffb30 000004d0`fffffb30 : 0x0000202e`474e5548
00000000`3490c840 00007ffe`83cafd99 : 00007ffe`80d377b4 00000000`00000001 00000000`3490dbb0 00007ffe`4be4f3ec : ntdll!RtlUnwindEx+0xe0
00000000`3490ca50 00007ffe`80b8ace2 : 00007ffe`80d377e4 00000000`3490daf0 00000000`3490dbb0 00000000`00000000 : ntdll!_C_specific_handler+0xd9
00000000`3490cac0 00007ffe`83cc477f : 00000000`00000000 00000000`3490d060 00000000`00000000 00007ffe`80b00000 : KERNELBASE!_GSHandlerCheck_SEH+0x6a
00000000`3490caf0 00007ffe`83c24bef : 00000000`3490d060 00000000`00000000 00000000`00000000 00007ffe`80b00000 : ntdll!RtlpExecuteHandlerForException+0xf
00000000`3490cb20 00007ffe`83c289e6 : 00000000`3490d290 00007ffe`83c287d1 00000000`3490d290 00000000`00000000 : ntdll!RtlDispatchException+0x40f
00000000`3490d250 00000000`00000000 : 00002ad9`73fdb78d 00007ffe`80b257a3 00000000`00000002 00007ffe`80b1f3bd : ntdll!RtlRaiseException+0x316
THREAD_SHA1_HASH_MOD_FUNC: ca5f3522079e743716170cd795f24abc64e1f51f
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: e2ba14bcf6f206fef64b7592b863a120b5a897f0
THREAD_SHA1_HASH_MOD: fd3993ac99a0867a95fe80a5898c8d0920148e13
FOLLOWUP_IP:
bfv+1ff1405
00000001`41ff1405 ?? ???
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: bfv+1ff1405
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: bfv
IMAGE_NAME: bfv.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 5ce71974
STACK_COMMAND: ~15s ; .ecxr ; kb
BUCKET_ID: APPLICATION_FAULT_bfv+1ff1405
FAILURE_EXCEPTION_CODE: 887a0006
FAILURE_IMAGE_NAME: bfv.exe
BUCKET_ID_IMAGE_STR: bfv.exe
FAILURE_MODULE_NAME: bfv
BUCKET_ID_MODULE_STR: bfv
FAILURE_FUNCTION_NAME: Unknown
BUCKET_ID_FUNCTION_STR: Unknown
BUCKET_ID_OFFSET: 1ff1405
BUCKET_ID_MODTIMEDATESTAMP: 5ce71974
BUCKET_ID_MODCHECKSUM: f2f46ca
BUCKET_ID_MODVER_STR: 1.0.73.12205
BUCKET_ID_PREFIX_STR: APPLICATION_FAULT_
FAILURE_PROBLEM_CLASS: APPLICATION_FAULT
FAILURE_SYMBOL_NAME: bfv.exe!Unknown
FAILURE_BUCKET_ID: APPLICATION_FAULT_887a0006_bfv.exe!Unknown
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
