16805 Discussions
comparing two mobile CPUs (T5500 vs T7300)
Hi
I have a Toshiba Satego P100 10F.
here some specs:
CPU Core 2 DUO T5500 2x1.66 (PBGA479, PPGA478)
2GB RAM
7900GS 512MB
This notebook ist going to be 3 years old and it can't handle the newest CAD programs and games as well as when it was brand new.
A friend of mine has got a broken notebook with a C2D T7300 (2x2.00) which I could have.
Recording to the Intel CPU list the T7300 should fit on my mainboard.
The exact line says: "Sockets supported: PBGA479, PPGA478"
Does that mean that a T5500 (or a T7300) can fit in a socket 479 as well as in a 478. Or does it say that there are 2 socket versions of each processor?
//Don't worry. I opened my notebook many times before. I know what I'm doing
I hope you can help me
Thanks!!
The T7300 won't work in your laptop. T5500 is a socket M processor, and the T7300 uses different socket - socket P. If your laptop motherboard has socket 479 then the T7300 will physically fit in it, but won't work in it. There is also a chance that your motherboard has real socket M, then the T7300 won't even fit into it.
Gennadiy
hmm, are you sure?
This table shows the same sockets at both CPUs.
http://ark.intel.com/Compare.aspx?ids=29760,27253 http://ark.intel.com/Compare.aspx?ids=29760,27253,
A system information tool on my computer tells my that my socket is "479 Ball uFCBGA / 478 Pin uFCPGA"
So I have a socket M (=478?). And socket P has 478 pins as well but doesn't match with socket M?
thanks, regards
Can you tell me which CPUs are compatible with my mainboard? I thought is was the whole T7xxx and T5xxx series.
ok, I think I found an answer to my problem...
I've got a Socket M CPU. And found some compatible cpus to my mainboard:
Merom-2M
Core 2 Duo T5300 1733 2048 533
Core 2 Duo T5500 1667 2048 667
Core 2 Duo T5600 1833 2048 667
Merom
Core 2 Duo T5200 1600 2048 533
Core 2 Duo T7200 2000 4096 667
Core 2 Duo T7400 2166 4096 667
Core 2 Duo T7600 2333 4096 667
aargh, exactly the T7300 is a socket p one.
So I'm looking out for a T7-(2/4/6)-00 on ebay.
Please check your processor first. There were two versions of the T5500 - in micro-PGA and micro-BGA packages. It's likely that you have a micro-PGA package, but if you have a micro-BGA package, soldered on the board, then you won't be able to upgrade it.
Gennadiy
thanks for your reply and your hint
Can you tell me how I can be sure which socket module is in my laptop?
I don't know where to look.
As I told you I opened my notebook a couple times before. I also renewed the thermal paste on the cpu/nb/gpu/vram.
But I didn't even tried to get the cpu out if its socket.
hmm, I guess the easiest way to get it out is to open it once more. costs me 1.5h ^^
Since you already cleaned it / replaced the thermal paste then maybe you don't need to open it. If you remember that the chip was in a socket then you have micro-PGA version. If it was on the board, without the socket, then it's a BGA version. You can also detect the version from the S-Spec number (if you know it, or you can look at the CPU itself), or from the markings on the CPU: BGA version has "LE80537" on the top, and PGA version has LF80537. CPU-Z may show package/socket type, but I don't know if this information can be trusted or not.
Gennadiy
Thanks a Lot !!
Yeah, I can remeber. There was a socket like on a normal desktop mainboard.
problem solved, great help!
