16774 Discussões
core 2 duo e7500 utilizing only one core
Funcionário
3.149 Visualizações
please help im having an intel core 2 duo e7500 when i go to rating it shows only one core in my cpu even in ms config i cant select more then one core because of this issue my pc shows black screen in every racing game which need atlease 2 cores pls tell me how can i enable second core of my cpu
see the screenshots below to see my problem
4 Respostas
Funcionário
2.021 Visualizações
Hello vanshaj,
Try checking your BIOS configuration for the cores, you should be able to see the cores and if possible enable/disable them.
Amy C.
Funcionário
2.021 Visualizações
i have a option in bios its SW single processing mode it was enabled and i had disabled it but nothing changed there is still one core in use
Funcionário
2.021 Visualizações
/thread/115335 vanshaj, you may try updating your BIOS to the latest version available from our end: https://downloadcenter.intel.com/download/18881/BIOS-Update-PRG3110H-86A-?product=50375 Download BIOS Update [PRG3110H.86A]
Amy C.
Funcionário
2.021 Visualizações
/thread/115335 vanshaj, If you need further assistance let us know.
Amy C.
Responder
