16774 Discussions
fix your high end cpus or watch people flock to amd.
Crashzero
i have 14900ks, and its sucks cause i cant play any of my games, changed p1 p2 253 and icc to 307 but to no avail. i tried contacting intel but get looped around to nowhere. and now im over 30 days for warrenty so great work intel.
pressed_for_time
Valued Contributor II
I'm just a user of Intel 14th gen hardware like you.
Changing a handful of BIOS settings is unlikely to work. I assume you have updated to the latest BIOS. The Intel Default Settings Performance or Extreme are groups of settings that vary between the two options. Pick Performance to start with. Do not run any software that overrides the BIOS settings. Do not manually change any settings in the BIOS.
Ensure you have the latest chipset and ME drivers for your motherboard.
One user with similar issues to you solved it by changing out their boot SSD, so don't assume that it always the CPU that's to blame.
There is at least one game where starting it results in a crash with the error 'Unhandled Exception: EXCEPTION_ACCESS_VIOLATION'. The cause of this error is the use of MSI Afterburner.
You say you can't play any of your games. What games are they, and what errors are you seeing?
JeanetteC_Intel
Hello Crashzero,
Please check your email regarding this concern, so I can help better.
JeanetteC.
