16851 Discussions
i have this problem with my laptob where my cpu frequency, wich is I7-8550U, drop to 400mhz while gaming its normal max freq is 1.80 up to 2.0 Ghz pls help
mball10
that's my normal freq it falls to 0.40Ghz while gaming
n_scott_pearson
Sounds like you have throttling occurring. You will need to watch temperatures to know whether this is as a result of temperature or as a result of power. If it's temperature, you need to improve your cooling solution. If its power, you need to call your motherboard manufacturer and ask them why.
Hope this helps,
