i5 1235U
Hani_H
Hello
I intend to buy a laptop with intel (i5 1235U), i want to know if it will be suitable for my applications usage with a good life span, Apps are the following:
1. Microsoft Office 2021 (Word, Excel, Power Point, Access, Outlook)
2. Adobe Acrobat DC Pro 2020
3. Autonavisworks 2018 (navigation only for 3D Models)
4. C++ Programming
** Laptop other Specs:   512 SSD, 8 GB ram, MX550 2G (Lenovo Thinkpad)
IsaacQ_Intel
Hello @Hani_H
Based on the description of your concern, its advisable to check if all those software programs meet the requirements, for that please check our investigation results:
·      Office 2021 Minimum requirements:
  •   CPU: 1.1 GHz or faster, 2-core.
·      System Requirements | Adobe Acrobat Pro 2020, Acrobat Standard 2020:
  •   CPU: Intel® or AMD processor, 1.5GHz or faster processor
·      System requirements for Autodesk Navisworks 2018 products:
  •   CPU: Intel® Pentium® 4 or AMD Athlon™ 3.0 GHz (or higher) with SSE2 technology.
·      C++ Programming requirements:
  •   CPU: Intel Core 2 Duo, Athlon X2, or better
According to the details provided on the Arc website Intel® Core™ i5-1235U Processor, the CPU operates at frequencies ranging from 1.3 to 4.4 GHz for the performance cluster and 0.9 to 3.3 GHz for the efficient cluster. In essence, the processor specifications indicate compatibility with the mentioned software programs. Nevertheless, it is recommended to verify the compatibility of all other components, including HDD, GPU, RAM, OS, etc. To ensure accurate information, please reach out to the software developer or laptop manufacturer for comprehensive assistance regarding system and software compatibility.
Isaac Q.
Hani_H
Thanks Issac for clarification
So I shall be able to run office and Adobe easily, while autonavisworks shall require boost turbo frequency
For others specs regarding gpu, ram, storage:
2G Nividia M550
8GB ram ddr4, 3200
512 SSD m2.2242
Another question is it preferred to consider i7 1165G instead of i5 1235u for above applications running , or i5 1235u is better?
IsaacQ_Intel
Hello @Hani_H
Thank you for your response.
Both CPUs are deemed suitable; however, the selection between them should align with the user's specific requirements. Please refer to the attached comparison table for a detailed overview of the distinctions between the processors.
Isaac Q.
IsaacQ_Intel
Hello Hani_H
We hope you are doing fine.
Let us know if you still need assistance. Otherwise, the thread will be closed.
Isaac Q.
IsaacQ_Intel
Hello Hani_H,
Best regards.
Isaac Q.
