16771 Discussions
i5 12600k won't overclock
Data129
My i5 12600k won't overclock and is locked at 4.5ghz except for when idling, it drops.
I can't overclock it in the intel extreme tuning utility. Almost everything is greyed out. Overclocking in the bios is disabled also.
How exactly does the turbo boost work?
does it boost the frequency for a second or two at 4885mhz then drop down to 4554mhz? Under load. It doesn’t stay at 4885mhz under load.
Motherboard: Asus B660M Plus WiFi
AlHill
Update your bios.
Check your bios.
[Waiting for Windows 12]
Data129
I did do that same results.
Data129
when i go to change the clock multiplier in the bios, it just goes back to 45
Data129
Is it the mother board or the cpu that’s locking the speed?
megan3000
Valued Contributor I
Most likely this is a BIOS issue.
Those types of settings and controls rely on the BIOS and manufacturers may decide to limit overclocking capabilities. My understanding is that windows-based tools for overclocking or other BIOS settings also rely/depend upon the interface or API that is offered by the BIOS to access those settings/controls.
Yes, you need to check this first with the motherboard vendor...
Also, note that there are some concept misunderstandings here...
P-core base frequency is 3.70GHz and e-core is 2.80GHz...
Going higher than 3.70 is actually a sign that turbo boost is working since it is going beyond the base frequency. This would also apply to overclocking... Remember that boot frequency depends on different factors like thermal and power headroom.
You can learn more here:
https://www.intel.com/content/www/us/en/architecture-and-technology/turbo-boost/turbo-boost-technology.html
https://www.intel.com/content/www/us/en/gaming/resources/turbo-boost.html
https://www.intel.com/content/www/us/en/support/articles/000007359/processors/intel-core-processors.html
The last link reads "The amount of time the system spends in turbo boost mode depends on workload, environment, and platform design."
Data129
When the cpu is idle the frequency will be 4.9ghz when under load it will drop to 4.5ghz. Is that backwards? It doesn’t make sense to me.
TerryG3535
Is the processor getting too hot and throttling?
Data129
megan3000
Maybe it doesn't make sense... still, you're getting a higher frequency than the base frequency...
In the case that there was a real issue here, it would have been a BIOS issue (as the first suspect)
The strange thing is that OC settings are also disabled in BIOS... from what I've seen, it is most likely to be a BIOS issue than a CPU issue... also, I would check/tweak power plans on Windows and BIOS...
Data129
The power plan in windows is on high performance. In the bios, the power saving is off. The motherboard is with Asus being diagnosed I suspect you’re right it being a bios issue. Either they will replace the bios and tweak to accommodate the newly released i5 12600k. I have tried beta and older versions of the bios with no luck.
megan3000
hope the diagnostic and what they doing or a new BIOS may lead to a solution... fingers crossed!!
Kandis
there is still this problem even in 2025, I have an MSI motherboard, PRO B760-P WIFI DDR4 and I suffer the same way. When I'm not playing I have 4.9 and when I enter a game I have 4.5 and it doesn't increase any more, the temperatures are below 80 degrees so there are no limitations. I informed myself as much as I could and I understood that the fault would be that I have a B motherboard and to be able to get rid of this limitation I should have a Z one.
Kandis
if you've bothered to tell me, I've actually tried everything
