i5-1345U USB woes
windows_guru
I have an i5-1345U CPU is my Dell laptop. I see USB4 in several locations in the UEFI so I figure that is about all I have with any speed.
The two USB-A ports are USB 3.0 claimed USB3.2 but USB 3.2 is 20 gigabit. The USB-A are marked 5 gigabit in the plastic beside the connector. 5 gigabit is USB 3.0 speed.
Misrepresenting is par the course but given my processor is a U series I figure it had some power limitations holding back the USB speeds.
Given my CPU pretty much is a SOC the machine had two SO-DIMM and a M.2 slot. There is also a socketed WiFi card. I also have a 5G cellular slot so the machine has some ability.
I have some USB-C y-cables and they also run at 5 gigabit telling me that USB speeds are far from USB 4.0 let alone USB 4.2.. It seems USB performance is lagging badly.
My my CPU is low power at 15W until I attacked a 135W PSU and the performance spiked. CPU evidently can use 55W with turbo boost. No wonder the CPU the CPU fan is so big.
I use a lot of USB attached storage as the Dell only has a Ml.2 2230 SSD slot which crimps internal storage a tad.
RandyT_Intel
Hello windows_guru ,
Thank you for reaching out to us regarding the issue you’re experiencing with your system. To better assist you, I need to gather some additional information. Could you please answer the following questions?
  1. Has this issue occurred before?
  2. Can you please run the System Support Utility (SSU) and share the logs with me?
  3. What troubleshooting steps have you tried so far to fix the issue?
  4. Have you tried using different USB cables and ports?
  5. Are all your drivers, including chipset and USB drivers, up to date?
  6. Have you checked the power settings in the BIOS/UEFI and within the operating system?
  7. Have you tested the USB ports with different devices to see if the issue persists?
  8. Have you noticed any changes in performance when using the laptop with different power supplies?
  9. Have you tried to reach out to Dell Support regarding this issue?
Please note that this is an OEM device, so we will try to assist you with general troubleshooting steps. However, if the issue persists, you will have to contact the Original Equipment Manufacturer of your device. Your device manufacturer may have altered features, incorporated customizations, or made other changes to some components for better compatibility with your system.
Providing this information will help me diagnose the system more accurately and check for available solutions. Thank you for your cooperation, and I look forward to your response.
Randy T.
windows_guru
I attached the text file created by your SSU utility
RandyT_Intel
I don't have an answer at this moment, but I'll investigate it and get back to you as soon as possible. I'm going to look into the issue further.
Randy T.
windows_guru
I installed a UEFI update last Friday so I am figure the UEFI had some issue but I did not find anything too severe.
Unlike older machines Dell allows read access to the UEFI rather than prompt for a password first. My old T14 does this and so does my Dell XPS 15 9570.
windows_guru
My machine has USB 4 and my iPhone 15 Pro has USB-C so I use that for charging Windows claims it could be faster in a USB 3 port. The UEFI on my Dell Latitude 5440 has 7.5W or 15W so I set it to 15W.
I noticed a bunch of Intel updates today suggesting at least somebody is making sure my 13th gen CPU and chipset are as free from BSOD woes as possible.
RandyT_Intel
Based on the information you've provided, it appears that the system architecture is customized with Dell technologies. Therefore, I recommend that you also check this concern with Dell's OEM support, as they may have specific insights and solutions tailored to their customized systems.
In the meantime, I will dig into your system information and look for recommendations from our database that might help address your concern. I will keep you updated with any findings or suggestions that could improve your USB performance.
Randy T.
windows_guru
My machine has a slot for 5G cellular which is definitely not a standard feature. I am considering a 5G carde in addition to upgrading the memory to 64GB so that the performance will be best possible.
The software I use trends to use a lot of memory with excel and some custom programs I have developed
RandyT_Intel
Thank you for your patience. I have my assessment; it appears that the readings you observe regarding USB performance are not indicative of a performance issue. The operating system recognizes the USB 3.0 port as a USB 3.2 Generation due to its backward compatibility. This behavior is influenced by the Original Equipment Manufacturers (OEM) setup of the USB version, and results may vary accordingly.
Regarding Intel updates, I can assure you that this segment of mobile devices is not affected by the known issues associated with boxed processors. Based on our analysis of the reported instability issues with Intel® Core™ 13th and 14th Gen desktop processors, Intel has determined that mobile products are not exposed to the same concerns.
Lastly, for inquiries related to upgrades or other technical details, I kindly recommend reaching out to your original device manufacturer. This falls outside the scope of our support as this is an OEM system.
Randy T.
windows_guru
AFAIK the USG Sig has something to say.
USB 3.0 is 5 gigabit
USB 3.1 is 10 gigabit
I read the manuals offered on the usbsig.org website, literature from vendors swerve all over the place from the standard
