16794 Discussions
i5-14500 SpeedStep not working
Mike109
Built a new system.
Intel i5-14500
ASRock B760M PRO RS/D4 Motherboard
G.Skill 16GB DDR4 RAM
Samsung M.2 SSD 970 EVO Plus
Windows 10 Pro
Problem is CPU is stuck at 2600 MHz.
BIOS > Advanced Mode shows Processor Max Speed: 2600Mhz and Min Speed: 400Mhz.
BIOS EZ MODE it indicates Processor Speed: 4600Mhz.
Intel states the Performance-core Base Frequency is 2600Mhz. Which happens to be what I'm stuck at.
HWMonitor shows all cores stuck at 2600 Mhz.
I tried to load the CPU by running many videos & programs at the same time. The CPU fan speed went from 1100 RPM to 3100 RPM so I figured the CPU must be under some load. But the cores never went faster.
I was also expecting the cores to slow down at idle with no load, like my old CPU did.
I did contact ASRock Technical Support (not the forum). They said to update the BIOS, which I did. But that made no difference. Then they said to try another CPU.
I found a thread on this forum where someone did have a SpeedStep problem & it turned out to be a defective CPU. Is this a common occurrence?
Does it look like the CPU is bad because the BIOS states the Processor Max Speed is 2600Mhz and Min Speed is 400Mhz?
ACarmona_Intel
Hello Mike109,
To help me further identify the problem and offer you a solution, kindly provide the following details:
  • When did you first notice that the CPU speed was stock at 2600 MHz?
  • Please provide a photo or video of the exact issue that we have.
  • Is it possible that you can try another processor on your system? so we can easily determine if the reported processor is faulty.
We look forward to your response!
Carmona A.
Mike109
I found the problem last night -
The version of HWMonitor I had was out of date. I thought it was working OK because it displayed temperature, voltage, fan speed, clocks, etc. Problem was the clock speeds were stuck at 2600MHz.
I installed HWINFO64 and it showed the clock speeds varying all over. This made me question HWMonitor. Installing a new version now shows the clocks varying all over.
I apologize for posting a problem that really wasn't.
ACarmona_Intel
Hello Mike109,
Thank you so much for the update, and no worries; we understand.
By the way, please let me know if you still need our help or if you already wish to close the case.
Carmona A.
Mike109
ACarmona_Intel
Hello Mike109,
Thank you so much for the response.
As requested, I will now be closing this case. If in the future you might need our assistance, please submit a new question, as this thread will no longer be monitored.
You are very welcome, and have a great day ahead!
Carmona A.
