i5 650 vs. Xeon
직원
2,549 조회수
Trying to decide between these two HP computers.
In this corner...
HP Workstation xw8200
3.80 GHz Intel Xeon (2 Installed) Processor with
- 16 kb Primary Memory Cache
- 2048 kb Secondary Memory Cache
- 64-bit ready
- Not Hyper-threaded
On an HP 08B4h Motherboard with
- 800 MHz Bus Clock
Currently with Windows XP (32-bit) and 6GB of RAM (but will likely be updated to Windows 7 (64-bit) in the future.
And in this corner...
HP Compaq 8100 Elite CMT PC
3.20 GHz Intel Core i5 650 with
- 64 kb Primary Memory Cache
- 256 kb Secondary Memory Cache
- 4096 kb Tertiary Memory Cache
- 64-bit ready
- Multi-core (2 Total)
- Hyper-Threaded (4 total)
On an HP 304Bh Motherboard with
- 133 MHz Bus Clock
Currently with Windows 7 (64-bit) and 4GB of RAM
I have this choice for my work computer in which I do some CAD design work and Spreadsheets galore! Please help me decide. Thank you,
0 포인트
1 응답
직원
1,684 조회수
Please keep in mind the system performance is not only dependent on the processor speed, but dependent on its specifications and entire hardware and software configuration.
The Intel® Core™ i5 processor I5- 650 (Retail boxed version; OEM/tray version specifications may vary) has the following specifications: http://ark.intel.com/products/43546/Intel-Core-i5-650-Processor-(4M-Cache-3_20-GHz) http://ark.intel.com/products/43546/Intel-Core-i5-650-Processor-(4M-Cache-3_20-GHz)
In regards to the Intel® Xeon Processor is use, it is an OEM/tray only unit, therefore, we do not keep track on its specifications since this is something that is then customized by the system builder at a BIOS level as they wish.
We recommend you contacting HP* for benchmarking data/comparison on the systems they are building.
0 포인트
응답
