16774 Diskussionen
i5-6500 100% use
Gauthierr
Anfänger
3.983Aufrufe
i bought i5-6500 but it's totally used it's marked 100% use so it's lagging my pc help plz
6 Antworten
AlHill
Superuser
3.974Aufrufe
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Gauthierr
Anfänger
3.968Aufrufe
its good and im french so maybe they are french in my folder sorry
AlHill
Superuser
3.949Aufrufe
I cannot see the model number of your asustek motherboard, and I cannot see your bios revision.  Do you have that information?
Also, I assumr you built this PC, is that correct?  Have you considered the installation of the processor needs to be done again?
This "100%" - is that only for a few minutes after startup, or all the time?
Have you checked your startup programs?  Do you have lots of PUPs installed?
Gauthierr
Anfänger
3.941Aufrufe
1. i don't have built my pc
2.The "100%" its all time
3. i have took screenshot of informations bios/mother board
4. my pc is old (4 years)
5. Have you checked your startup programs? Yes
6.Do you have lots of PUPs installed? Yes
AlHill
Superuser
3.929Aufrufe
I would start by disabling some of the startups.  But, if you do have lots of PUPs, you should get rid of them.  MALWAREBYTES.ORG does a particularly good job of identifying and removing PUPs.  And, it is free.  Just download it and clean up your machine.  I just ran that on a friends machine and it removed 234 PUPs.  It took two passes, but the PUPs are gone.   And, it may identify other viruses.
After that, let us see where you are.
n_scott_pearson
Superuser
3.918Aufrufe
For the 100% usage, please open Task Manager, select More Details (lower left corner), select the Processes Tab and then select the CPU column (so it sorts processes by utilization). Take a snapshot of this display and attach it to a response message.
I would also like to see a thermal sensor display from a program like AIDA64, HWiNFO64 or something similar.
Antworten
