告知
16855 ディスカッション
i5 7200U stuck at 0.38Ghz - Miix 720 12IKB
ADArd
初心者
30,644件の閲覧回数
HI
I bought my computer in february, and all was running smooth (except my backcam non recognized at 5mpx but at 2.09mpx) regarding cpu wasn't any problem.
That until Creator Update hits.
My problem is very simple. My cpu is stuck at 0.36ghz whatever i do, playing game watching film ot anything else..i suddently noticed it when happened because the system did the same things that always did in 5-6 times slower way. This was happened in middle October.
I updated bios form lenovo, i updated all drivers from lenovo too. I uptaded all drivers from windows updated hoping from a solution..nothing. I also used a tool DriverEasy to check the lastest diver avable not showing on windows update, after checking the matching drivers i manually istalled it to a newer version if avable.. but my problem persisted.
that until first days of november when a big update "x64 widnows comabibility something.." shown on windows update, i istalled it, and system was running fine again.
This update also modified the energy management erasing all anergy profiles, setting it to a new configuration with a long bar where you can choose between high saving and max performance.
To avoid any further problem i disabled Windows Update in Services and my system was fine... or at least i hope so BUT 10 days ago without any update during normal use, my processor was back to 0.38 Ghz.. same symptoms..
Re-enabled Windows update, deploying last drivers from lenovo too, didn't help once again.
I'm using my pc at 0.38 and is like a jump in the past when i was using Windows 98, this is a pic running a game when the first time problem occurred.
13 返答(返信)
従業員
23,182件の閲覧回数
Hello Nanami,
Thank you for contacting Intel® technical support. I will be more than happy to help you.
I understand that you are having issues with the Intel® Core™ i5-7200U in your Lenovo™ computer. Since the processor is not able to work higher that 0.38 GHz, please check the Power Options in Windows® 10 to confirm that it has not been set up to limit the system usage.
Additionally, you can diagnose the processor. You can install the Intel® Processor Diagnostic Tool to run a test in the processor, and you can install Intel® Extreme Tuning Utility to run a CPU stress test. Please use these tools and let me know the results.
You can download these tools with the links below:Regards,
Xavier A.
ADArd
初心者
23,182件の閲覧回数
i did all you said, here the results: no limit of CPU is set in power managment (but i did tests in past days and changing minimum value of CPU do not affect the CPU, stil 0,38Ghz even if you set 50%, 70% or so on)
I run the diagnostic test first, and i passed all test, but i noticed that processor % usage didnt match the windows CPU activity % usage. The cap was always 0.38 GHZ during all tests.
Then i did the Exreme tool test with CPU stress test 5min. The result prove the data spotted before. CPU usage 100% with 0.40ghz max cpu usage. Windows % usage always was different but cap was also the same(0.38Ghz). Isn't a matter of vIruses according Panda Antivirus with lastest virus definition.
従業員
23,182件の閲覧回数
Hello Nanami,
Thank you for the information provided. There are a few additional troubleshooting steps you can try.
First, access your system BIOS and load its default settings. Then, still in the BIOS, disable the Intel SpeedStep® Technology.
Later, access Windows®, and download and install the Intel® Processor Identification Utility. Please use the next link to get this tool: https://downloadcenter.intel.com/download/7838
This tool will test the processor at two speeds: the Expected speed, and the Reported speed. Please let me know what is the Reported speed. If possible, please attach a screenshot.
Xavier A.
ADArd
初心者
23,182件の閲覧回数
HI,
My BIOS do not allow to disable SpeedStep that is not listed at all. I'm using lastest Lenovo BIOS version, you can check the previously pic to find the bios model, in my previously answer.
Loading default settind didn't help.
But i discovered any findinggs could be potentially useful. According ThrottleStop the problem is that my multiplyer is stuck at x4 whetever it takes, even if my CPU temp is 34 degree.
Disabling "DB PROCHOT" affect my cpu and mutiplyer come back to x31.
But this isnt a permanently solution because everytime my computer go sleep or switch off screen i have to re-launch progroma and doing so it disable DB PROCHOT again.
Morover the program do not affect the boot time in witch CPU is fixed at 0.4 with boot time six-seven time slower then usualy was. Here some shots
Please fix that is wrong permanently.
n_scott_pearson
スーパーユーザー
23,180件の閲覧回数
I hate to be this blunt, but why are you here? This is obviously an issue with software/firmware and/or Windows. You should be asking Lenovo for help resolving this issue, not Intel. What are they saying when you ask on their forums?
ADArd
初心者
23,180件の閲覧回数
Lenovo said to do a factory reset wiping data. This solved the camera problem but the processor still stays the same. The only thing that affects the processor is manually disable DB PROCHOT.
How can I permanently disable DB PROCHOT (PROCHOT stay for processor hot, but my processor is 37 degree)? I blame windows creator update for this.
n_scott_pearson
スーパーユーザー
23,180件の閲覧回数
Again, this is a question that you need to be asking Lenovo, not Intel. Lenovo designed the board and Lenovo implemented the BIOS and Lenovo built your system. Lenovo is thus your primary source for support. Tell their customer support people that you do not want to be caught in the middle. Tell them that, if they want to blame the issue on Intel, it's their job to to bring this issue to Intel's attention, not your's.
AFari1
ビギナー
23,180件の閲覧回数
I have the same problem in a Asus F541UV. Latest 035 bios from 2018, all updates in windows 10 (including fall creators). i5-6200 always at 0,38GHz (performance mode).
Just saw this three solutions:
- Disabling Virtual stuff in bios
- Driver wise
- Use thottlestop
https://forums.lenovo.com/t5/Lenovo-Yoga-Series-Notebooks/Yoga-3-11-CPU-stuck-at-0-48-Ghz-99-of-the-time/m-p/3357788# M42310 https://forums.lenovo.com/t5/Lenovo-Yoga-Series-Notebooks/Yoga-3-11-CPU-stuck-at-0-48-Ghz-99-of-the-time/m-p/3357788# M42310
Maybe it will help you. As soon as I can I will test.
MHind
ビギナー
23,180件の閲覧回数
Try and update the drivers for Intel Dynamic Platform & Thermal Framework to see if anything changes. In the link skinnie provided the suggestion is to uninstall these drivers but this may result in system instability. As far as I am aware these drivers regulate the CPU speed with regards to internal temperature (not necessarily CPU's).
Also check your Event Viewer and look for any warnings or errors related to Intel DPTF and its services under System and Applications. I had to reinstall Windows to get the services for DPTF working properly however I still have a warning related to it showing up when I reboot my computer but not when I shut it down and boot it up.
I have the same processor i5-7200U however my problem is a bit different, my CPU runs at 3.08GHz on high performance but downclocks to base frequency 2.50 GHz when it reaches 80°C. This behaviour is supposedly caused by Intel DPTF and to get around it some people simply uninstall its drivers. Since we both have the same processor I wonder if you'll have the same issue once you fix your initial problem.
ADile
ビギナー
23,180件の閲覧回数
take out your laptop's battery, wait maybe 10-15seconds and re-insert it. Some users online have claimed this works (for me too).
I would like to clarify this, in order for this to work, unplug the power cord from the laptop and remove the battery from the laptop. Next thing you will want to do is try to boot the Laptop whilst you do not have an battery or power cord attached, this will reset the CMOS. On a desktop you would be able to easily remove the CMOS battery, but I don't suggest to fiddle with this on your new laptop. When the CMOS is reset the laptop will boot with factory instructions rather than the instructions it has in its memory.
GSamk
ビギナー
23,181件の閲覧回数
I had same problem and found this solution :
  1. Go to Manage > Device Manager
  2. Uninstall all driver and software of Intel Dynamic Platform & Thermal Framework
  3. Turn off Windows Automatic Updates from Services.msc and Turn off Configure automatic updates from gpedit.msc
  4. Turn off Intel Dynamic Platform & Thermal Framework from services.msc
  5. Set power plan to Maximum Performance
**I had same problem with Asus Laptop i5 7200U. It was stuck on 0.38Ghz while playing games, so now works fine on 3.09Ghz ;)**Good Luck
MSon1
ビギナー
23,180件の閲覧回数
I had the same problem with Asus Zenbook UX410UQK i7-7200U processor months ago.
I read somewhere on Internet that this caused by battery monitoring wrong capacity, which can be fixed by:
  1. Full charging the battery.
  2. Unplug the charger, use the laptop until battery is empty and shutdown automatically.
  3. Wait a minute and turn on and continue using till it cannot be turned on again (to make sure the battery is empty).
  4. Recharge and use as normal.
Process with your own risk. That worked for me. But after months of using I'm now facing the problem again, maybe the battery's capacity dropped and the monitoring circuit didn't monitor it right.
I'm now repeate steps above!
TSham
ビギナー
23,181件の閲覧回数
I had a similar issue on Lenovo T480 with CPU maxed at 0.38 Ghz
After a LOT of trial an errors, found the issue. Go to Lenovo Support and install Thermal Framework Driver under Chipset section.
返信
