I wouldn't consider these temperatures as being too high in either case. If it never goes above 87c (other than very short duration spikes), then the processor will be happy and good for its warranted lifetime.
Actually, your solution could be making it worse. Those 5 inlet fans could be pulling in more air than can be exhausted by that one fan (and other openings). This can result in a positive pressure buildup inside the chassis, causing standing air and this can make the cooling ineffective. As well, if you have a AIO, its radiator and fans should be exhausting the heated air directly out of the chassis. If it isn't, it is contributing to the problem.
So i did change my fan orientation and i made the top 2 exhaust and the rear exhaust while leaving my front 3 on intake. It did not make much of a difference and my cpu even spiked up to 100c during playing cyberpunk 2077 earlier. I don’t want my cpu to overheat and get damage caused to it and i dont know what to do.
Hello Josh66, I just wanted to check if you need further assistance on the overheating scenario?
Albert R.
I am in the midst of getting a new liquid cooler from corsair but i would still like to know if my 14700k hitting 100c in games is okay?
Josh66, Thank you very much for your response.
Excellent, it is great to hear that you are getting a new liquid cooler from Corsair.
Sure. For this scenario is it important to mention that the T-junction of Intel® Core™ i7 processor 14700K procesor is 100°C. Any temperature result lower or equal to that value is considered normal and expected for this unit:
In order to rule out a possible hardware issue, please install and run the Intel® Processor Diagnostic Tool, it does an overall test on the processor and it if passes the test it means it is working properly:
Just in case, here you have the "Overheating Symptoms and Troubleshooting for Intel® Boxed Processors" for you to confirm if your processor is actually getting overheated and with additional information on this subject:
Albert R.
Hello Josh66, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Hello Josh66, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
