16797 ディスカッション
i7-3770 - Only Running on 2 cores 4 threads - Processor problem ??
従業員
4,921件の閲覧回数
Good Day ..
Processor shows up in device manager as 8 threads
Go into Config sys- boot - set for 4 cores
Sys info shows 2 cores 4 threads
Processor is sitting in a ASUS P8Z77-v LE Mobo
Generic optimized settings in bios - not an overclocker
Running cool 35-36c
Newest bios for board 2/13
Windows 8 Pro
Asus utility says 2 core 4 threads
Using Intel's diagnostic utility hangs on testing cache ...
Sounds like a bad processor to me ... thoughts ?
Thanks for your time
0 件の賞賛
1 返信
FGonz6
新規コントリビューター III
3,622件の閲覧回数
Hello Mike Bonnell,
We would suggest you to run the resmon.exe command within windows and monitor how many processor cores are showing. Furthermore, you can also open the windows task manager and select the performance tab to see how many cores are being detected.
Also leaving resmon open go to control panel>system>windows experience Index and click on Re-run the assessment. While running this go back to resource monitor and check how many cores are working.
返信
