- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I recently bought Lenovo T440P with i7-4800MQ which is suppose to be able run with up to 3.7GHz speed, but once I received it I noticed when running computational intensive simulations it never reaches above 2.7GHz. Also in PC information I can see it shows clock speed of 2.7GHz (I also checked in BIOS same store, shows 2.7GHz).
My initial guess is that Motherboard is not able to support max speed of the CPU, but I am not 100% sure. Or is there something that should be set to take advantage of full power of CPU?
I am not sure why Lenovo would install powerful CPU on the motherboard that can't handle full power, if that's the case.
Does anyone have any idea why this could be happening?
My CPU-Z report attached.
Any comments or ideas would be appreciated.
Thank you.
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
This feature is called Intel® Turbo Boost Technology and it depends on whether the motherboard BIOS supports it and if it is enabled in the BIOS settings. Once supported and enabled, Intel® Turbo Boost Technology works automatically depending on power, temperature and workload.
Our best recommendation is to check your BIOS settings or contact your system manufacturer for further assistance.
http://www.intel.com/support/processors/sb/CS-029908.htm Processors; Intel� Turbo Boost Technology frequently asked questions
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
