- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi, I have high temperature with the i7 7700k when I do load test to 100%. They ocillate between 80° and 85°. The ambient temperature is around 24°.
The processor has teir stock values (No OC)
The Temperatures are correct? Do not compromise the useful life of the processor? What are the normal operating temperatures?
The specifications of my system
- Processor: i7-7700k
- Mother: Gigabyte Z270 Ga Gaming
- Memory: 16GB Corsair 3200mhz Vengance LED
- Power Supply: Corsair VS650
- Graphics: Gigabyte GTX 1060 3GB
- Cooling: Corsair H100i v2 Liquid
- Case: Corsair Spec Alpha with 5 FANs 120mm
The airflow in the cabinet is correctly configured
Carlos
- Tags:
- HP Desktops
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Carlos,
I would like to start by explaining that the TJUNCTION for this specific model is 100°C, this means that any number below this temperature is completely fine. One more thing I would like to let you know is that running a load test is a CPU intensive task meaning that it will add workload to the processor and therefore, the temperature will go up.
Regarding the tool you are using, Core Temp, I am aware that the first column(see below) shows the current value of the processor. This means that you should be focusing on that column when running the test instead of Max column. The Max column is just for reference for the maximum parameters that your processor could reach, it does not indicate the temperature when the computer is running.
Based on the explanation before, these temperatures(on the green square) are completely fine. The unit is behaving as expected.
If you have more questions, please let me know.
Amy.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Carlos, hope the information was helpful.
Amy.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks Amy for the explanation. It was useful for me. Sorry for not response on time.
Regards.
Carlos.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Not a problem Carlos, I am glad to hear this was helpful.
If you have more questions regarding this or any other matter, please just let me know.
Amy.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
