16769 Discussions
intel 285k error build AOSP
AMV007
Hello, got constant crash with build AOSP 13 at intel 285k and 265k.
OS: Ubuntu 22
kernel: 6.8.0-49
command for download and build:
echo "start download $(date)" && \
repo init --depth=1 --no-tags --current-branch -u https://android.googlesource.com/platform/manifest -b android-13.0.0_r83 && \
repo sync --current-branch --no-clone-bundle --no-tags && \
echo "start building $(date)" && \
rm -rf out &&\
source build/envsetup.sh && \
lunch aosp_arm64-eng && \
export LC_ALL=C && \
sed -i 's#!/usr/bin/python.*#!/usr/bin/python2#g' device/generic/goldfish/tools/mk_combined_img.py && \
make -j$(nproc --all)
may be any1 know how to fix it ?
(same task on 13900k with the same memory working without any problems)
Earl_Intel
Hi AMV007,
I'm sorry to learn that you are experiencing issues with your system. To better assist you and determine the most appropriate resolution, could you please provide the needed details listed below.
  • May I know if the processor is working fine before?
  • How did the issue happen?
  • Are there any changes on the system before you encounter this issue?
  • What are the troubleshooting steps you already tried?
  • May I know the make and model of your motherboard?
Once we have this information, we will be able to proceed with the next course of action and work towards resolving the issue you are facing.
Earl E.
AMV007
Hello, happy new year !
all fine, AOSP 10 compiling without problems before and after problem with AOSP 13.
no thermal throttling, temps are ok
just run compilation again and again, after I got a problem I go to seller of CPU and he found total different hardare set with MSI MB with water cooling and 265k, I tested here too - with same result so problem definitely not in my hardware, may be in all intel CPU generation totally.
no
I got instability firstly with 14600k before, and simply solved it by lowering down  CPU freq.
but here it not helping, tried low down CPU freq, RAM freq - no difference
checked RAM - no errors found
stress-ng -- cpu 24, compile AOSP 10 with j24 - all ok
ASUS TUF GAMING Z890-PLUS WIFI
with latest BIOS
RAM: UD5-6800 96 Gb.
also same RAM with 13900k, 14900k before - all ok with compile AOSP 13.
Earl_Intel
Hi AMW007,
Thank you for sharing this useful information with us.
I will further check on this internally and will provide an update on this thread as soon as possible.
Earl E.
Earl_Intel
Hi AMW007,
Thank you for patiently waiting on us.
Considering your situation, try checking the instructions supported by our processor: https://edc.intel.com/content/www/us/en/design/products/platforms/details/arrow-lake-s/core-ultra-200s-series-processors-specification-update/
You can also try to contact Google Support regarding the build issue that you're experiencing.
Earl E.
AMV007
Hello
>>User account '**bleep**@outlook.com' from identity provider 'live.com' does not exist in tenant 'Intel Corporation' and cannot access the application '80ccc919-1e89-4cc5-a276-46064e02d51f'(Structured Content Publishing Tool Client) in that tenant. The account needs to be added as an external user in the tenant first. Sign out and sign in again with a different Azure Active Directory user account
when trying to access this link.
can you give another link ?
are you mean that arrow lake not support the same instructions as 13900, 14900 because not have problems with them ?
AMV007
Hello, thank you for info.
trying to access link you provided, got:
User account '**bleep**@outlook.com' from identity provider 'live.com' does not exist in tenant 'Intel Corporation' and cannot access the application, can you provide another link ?
I got random crash with arrow lake, but time-to-time AOSP 13 build is success (rarelly) this mean that all instructions are supported but there is instability in Arrow Lake CPU ?
Or you mean, that arrow lake not supporting same instructions set as 13900, 14900, that building without problems ?
Have you tried command for build that I provided ?
Are you contacted and raised this question to CPU technical support who can analyze CPU instability and they did tests ?
