16855 Discussions
intel E7500 compatibility problem
Hello. I bought a new CPU E7500 for my home PC and I'm having a problem that won't let me sleep. After installing the new CPU my Sapphire HD4870 won't send any signal to my monitor, unless I manually turn the PC off by pressing the power off button for a few seconds. Turning the PC on after this action would result in a normal booting. This way i could play for hours and the PC it's been on for 3 days now with no problems. So after any restart or shutdown from software, won't work. I used the HD4870 with my old CPU E4500 and there was no problem. I also tryed the new CPU with the old videocard and it didn't work so the new CPU is the problem for sure.
Thanks in advance.
Btw this is the configuration I'm using:
CPU: Intel Core 2 Duo E7500
Mobo: Intel DP35DP
Video: Sapphire HD4870 1gb (standard one)
PSU: Gembird 650W
Memory: 4Gb (4x1Gb) DDR2 Pc2-6400 (400MHz) Kingmax
Monitor: BenQ 2420HD
Hi Nerevah
What BIOS version do you have? If you haven't upgrade BIOS is probably best to do so.
In order to upgrade BIOS is probably best to put the E4500 then once upgraded try the E7500
Find below a link with the latest BIOS update.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2782&DwnldID=17930&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2782&DwnldID=17930&lang=eng
Span1shUk
BIOS version is 0572 15.07.2009 and it's the latest version.
VICTORY!!!
I downgraded BIOS from the latest version to the minimum required version 0484 (using the old CPU) and now everything works as intended.
I have no idea what the reason is but i don't realy care ... it's working and I'm a happy-happy panda!
I can only guess that for old motherboards the latest version of BIOS is not always the best.
Cheers all!
