16771 Discussions
intel XTU CPU/Memory stress test running for 1 second only (result is shown as "Passed")
Andorra
Hi all,
XTU (version 6.5.1.360) was working fine before Windows 10 Pro updated to version 1903. Any ideas what might be causing this? CPU (9900K) is not overclocked nor under/over volted. I reinstalled XTU but it didn´t help. Changing the default running time (5min) doesn´t help as well.
p.s. OS was freshly installed.
Any input is much appreciated.
Andorra.
Andorra
UPDATE: I installed an older XTU version (6.5.1.321) and the stress tests works fine now.
n_scott_pearson
If you are not overclocking or over/under-voltaging, why are you installing XTU at all? As a test or benchmark tool? There are lots of better tools that you could be using.
Andorra
