HI
I wanted to calculate heating value(Q) cpu Q8300 and I found formula about cpu power dissipation from intel cpu manual.
p=cv^2f
(where, p=power, c=capacitance, v=voltage, f=frequency)
formula is good but I had not capacitace value. (v and f values got from CPUID program.)
Can I get capacitance value from intel official value?
Actually I was calcuate c(capacitance) value already like this c=p/(v^2*f)
p=95w(TDP), f=2.5GHz, v=1.3625 I insert this values at max values so I got (c=20.5*10^-9 F)
this calcuate is correct? I hope so but I think it is incorrect. that's why I am asking you guys!
Hellon Jinwon,
Note that processor "capacitance" is not something we specify or something that is constant from part to part.
In general, you can use the equation P=C*V*V*f to determine what the processor's "dynamic capacitance" (Cdyn) once you've measured the power draw. "Cdyn" is workload dependent so it varies based on processor load. (in the equation, P=Power draw, C= Capacitance, V=VID,f= frequency).
Amy.
Let me investigate a little bit further on this and I get back to you as soon as possible.
Hellon Jinwon,
Amy.
