- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
i my specs as follows
asus rog rampage vi extreme omega x299 motherboard with lates bios 0802.
intel i9 10920x cpu
4x8gb 3600mhz corsair ram
i am trying to use IPM to set overclock coz when i try to oc manually through bios i get errors due to low vccsa voltage and i have no idea how to use them so trying to use this, all bios setting are at default and as recomended in the user guide except i could not locate intel wdt, tried updating drivers for motherboard resources but nothing has changed and i couldnt find it in bios either, what should i do, attaching the results from intel system support utility below, thanks.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Performance Maximizer has very specific requirements. Look in section 3.2.4 here:
One of the requirements is UEFI mode. You have legacy mode.
To convert to UEFI, the following is provided for your convenience:
https://www.tenforums.com/tutorials/81502-convert-windows-10-legacy-bios-uefi-without-data-loss.html
Doc
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Also, regarding the WDT.
In the device mangler, under hidden devices, system devices, you will see 5 to 7 "motherboard resources". WDT is one of those, but which one?
Right-click on each one, select update driver, search automatically. One of them will update to Intel Watchdog timer driver. If you have already done this, it may be related to legacy vs uefi. I just do not know.
I am told this will be provided in a future version of IDSA.
Doc
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
@al.hill in my bios secure boot is enabled with windows uefi enabled as well with csm disabled and hard drive that has OS is formatted to GPT so i dont know where you saw legacy mode in the attachment ( correct me if i am wrong in something here), thank you.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
@Al.Hill OK i disabled CSM and now BIOS shows as UEFI mode and i used driver easy to update drivers and finally see Intel wdt driver, so i have everything as recommended and reinstalled program fresh after all the recommendations achieved but it still says system requirements not met. uploaded SSU file again with changes showing in there, i am lost at this point and guess i just have to use Intel XTU, any more help appreciated.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Well I was frustrated to make it work for 2 days and couldnt find intel wdt and in some forums it was reported that driver easy found it so I had no choice and it did find it, i guess i have to use intel xtu maybe, thank you once again.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello LGOTT6,
Can you please provide a screenshot of the error you are getting? (Not compatible).
Do you have antivirus software? if so you might try to disable it for testing porpuses in some cases the antivirus might block the application.
Do you have any other overclocking software? It is recommended that you do not use Intel® Performance Maximizer in conjunction with other overclocking software.
Adrian M.
A Contingent Worker at Intel
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello LGOTT6,
Thank you for your reply.
Can you please attach the image again directly to the thread? I am unable to see it.
Just to confirm and further investigate it, are you installing the software from the following link:
https://downloadcenter.intel.com/download/29292/Intel-Performance-Maximizer-for-Intel-Core-X-series-Processors?product=188727
Adrian M.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello LGOTT6,
Please allow me some time to update the thread and further investigate it.
Adrian M.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
That tool is a mess right now and doesn't work for a lot of people. You also can most likely achieve better results yourself (seems like it generally overvolts Official Site).
What kind of Mobo do you have? You can look up general guides that tell you exactly what to do, basic manual overclocking is a lot easier than you'd think.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
@SJasp i have asus rog rampage vi extreme omega and i have tried to oc and ended up with 9C bios error due to low vccsa voltage or vtt voltage and i was stuck at vga bios loading error and i couldnt find any useful info about the safe voltages for vccsa, vccio and vtt and i have no idea how to proceed so i decided to try this.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
"Asus promised a micro-code bios to be released in late 2019 but here we are in 2020 without any update"
Post your complaints about ASUS on their site. Complaining about ASUS here is like complaining to Dixie Cup about the coffee.
Doc
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
i did already , a month goes by and no one responded , that's why i'm here since Intel announced all Mobo makers will release bios updates late 2019 , maybe they should know the bios is not out yet ?!!
