16774 Diskussionen
lowering screen refresh rate on laptop cause ghosting
DiP43ck
Anfänger
7.976Aufrufe
I have a problem with my refresh rate on laptop. I have black ghosting when refresh rate is lower than my native 144Hz. I noticed that when i enable g-sync. I know that g-sync synchronize refresh rate with fps. Games are mostly run 60-90fps and ghosting is visible between 60-120fps. I thought that g-sync is a problem so i disabled g-sync and use CRU to add custom refresh rate and i found out that even without g-sync my screen ghosting on lower refresh rate (on windows too). I tried everything (manufacturer drivers, factory rest, clean install of windows with erase all data, all possible mixed options in nvidia cp, some registry editing) and nothing helped. Also i am unable to change screen refresh rate (only with CRU) in device manager, windows display settings, Nvidia cp are showing only one option 144Hz. I need to try older driver for my intel uhd graphics to be sure that screen is damaged. I need drivers before 2021. Or if you know about some 3rd party program that can be used on laptop to reduce ghosting. My specs are:
Laptop GIGABYTE AERO 15 xc
I7- 10870H 2.20Ghz -5Ghz
Nvidia RTX 3070m
24GB ram, 500GB ssd + 2T ssd, Windows 10
intel drivers tested: 27.20.100.8783, 30.0.100.9836, 31.0.101.2115, 31.0.101.2127
Here are some videos from different game that show my problem (i was forced to record it on mobile phone because all recording softwares in pc did not record that ghosting effect). Run video with 0.25 speed if you not see it.
https://youtu.be/3y62SUYaZiI?si=xul_jA1BRgyZdn05
https://youtu.be/CZ1l9PVGJz0?si=pyw5za9TsocvjBbK
https://www.youtube.com/watch?v=1eLbLB81FIY&ab_channel=DiP43ck
https://youtu.be/MMpCDBIjjQQ?si=TeZbQG-ZKGRzIe0c
Beschriftungen (1)
19 Antworten
ACarmona_Intel
Mitarbeiter
7.927Aufrufe
Hello DiP43ck,
May we know when the issue started and what games you tried when the issue occurred?
Furthermore, have you tried disabling the Intel integrated graphics card and checking if the issue would still occur?
Here are the steps on how to disable your integrated graphics card:
1. Right-click the Windows icon.
2. Click Device Manager.
3. Expand display adapters.
4. Right-click into your integrated graphics casing, then click Disable Device.
We look forward to your response!
Carmona A.
DiP43ck
Anfänger
7.916Aufrufe
Yes. I tried that and did not helped.
DiP43ck
Anfänger
7.910Aufrufe
In all games and in windows too.
ACarmona_Intel
Mitarbeiter
7.851Aufrufe
Hello DiP43ck,
Thank you so much for your quick response.
Upon checking, here's the only available graphics driver for your Intel® UHD Graphics for 10th Gen Intel® Processors:
  • Version: 31.0.101.2127
  • Version: 31.0.101.2125
  • Version: 31.0.101.2121
Please also check these 3rd party links that offer troubleshooting instructions for resolving the black ghosting issue:
Furthermore, since you are using NVidia graphics, we highly recommend that you contact NVIDIA support and Gigabyte support for further assistance.
Carmona A.
DiP43ck
Anfänger
7.827Aufrufe
31.0.101.2127, 31.0.101.2121, 31.0.101.2125
I tried all of them and did not helped. I allready contacted Gigabyte, Nvidia, Windows support and they did not helped. I was thinking that maybe you can have some ideas/options that i can try.
ACarmona_Intel
Mitarbeiter
7.738Aufrufe
Hello DiP43ck,
Thank you so much for the response.
To confirm, does the issue also occur even if you are only using an Intel integrated graphics card? If yes, please generate an SSU report to help me further investigate the issue. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
Carmona A.
DiP43ck
Anfänger
7.688Aufrufe
Yes the issue also occur even if i am using only an Intel gpu. I have also one question. In windows/graphics settings i have option for VRR Nvidia gpu is activate but i dont think its working at all. Is there any way to find out if its even working? Shouldnt there be an option to change refresh rate when i have VRR enabled?
ACarmona_Intel
Mitarbeiter
7.626Aufrufe
Hello DiP43ck,
Thank you so much for the quick response.
The information I have obtained in response to your enquiry about VRR at NVidia is provided below. And by the way, you may also contact NVidia directly regarding their product, as they are the experts when it comes to their product features and settings.
I will now raise the case with our engineers for further guidance on what we can do with the issue that we have.
Thank you for your patience and understanding.
Carmona A.
DiP43ck
Anfänger
7.593Aufrufe
Sorry I didnt specificetd my question correctly. My question is if there is option to use VRR without g-sync. Because there is option to enable VRR in Windows/graphics settings. This option is only visible when i enable dGPU.
ACarmona_Intel
Mitarbeiter
7.518Aufrufe
Hello DiP43ck,
Based on my research, G-SYNC is NVIDIA's proprietary hardware and software implementation of VRR, which means that it is not possible to use VRR without G-SYNC. However, to double check, it's better that you contact  NVIDIA support regarding this as well.
Carmona A.
ACarmona_Intel
Mitarbeiter
7.521Aufrufe
Hello DiP43ck,
Thank you so much for patiently waiting on our response.
Based on the steps you've already taken, it seems we might be looking at a potential hardware-related concern. However, to further narrow down the cause, we would be grateful if you could provide us with a bit more information:
1. Could you specify the refresh rate at which the ghosting effect occurs?
2. Have you noticed this issue in other applications, such as web browsers, word processors, or even when navigating through folders, since it appears to affect the Windows environment as well?
3. It would be helpful to know if the ghosting is also present on the BIOS settings screen.
4. If it's feasible, please try connecting your computer to an external monitor to see if the ghosting persists on a different display.
These details will greatly assist us in diagnosing the issue more accurately. Additionally, I'm including a link to our article on  Image/Shadow Retention on Intel® Graphics, which may offer some useful insights.
Carmona A.
DiP43ck
Anfänger
7.424Aufrufe
Ghosting effect occurs between 60-120 Hz
Its everywhere when screen refresh rate is between 60-120 Hz (Windows, web browser, games)
No, Bios is without ghosting
Yes, ghosting  persists on a different display at some lower frequencies but there was option to change response time (overdrive) so on external display it can be fixed
ACarmona_Intel
Mitarbeiter
7.216Aufrufe
Hello DiP43ck,
We are checking in with you to see if you already have the answers to our questions so we can further isolate our issue.
By the way, if you have any questions, please let us know.
Thank you, and have a great day!
Carmona A.
ACarmona_Intel
Mitarbeiter
7.009Aufrufe
Hello DiP43ck,
Again, we are checking in with you to see if you already have the answers to our questions so we can further isolate our issue.
We will be waiting for your response!
Carmona A.
DiP43ck
Anfänger
7.003Aufrufe
No. Problem was not solved and i am out of ideas. I just do not get it. How could i have 144hz screen that not support lower refresh rate. It is unbelievable. I tried diabling Intel gpu and run only Nvidia but did not help, i tried only Intel and it did not help either.
ACarmona_Intel
Mitarbeiter
6.878Aufrufe
Hello DiP43ck,
Thank you so much for the response, and I'm truly sorry, as it seems that I haven't noticed your previous response to us.
I can feel how important it is for you to resolve this case, so I will now be raising the case again with our engineers so they can provide us with an appropriate recommendation. I will get back to you as soon as I have our engineers updates.
By the way, the information you provided in both your previous and present responses was all highly noted.
Thank you so much for your patience and understanding.
Carmona A.
ACarmona_Intel
Mitarbeiter
6.684Aufrufe
Hello DiP43ck,
Thank you so much for patiently waiting again for our response.
Since the issue persists across different GPU models and driver versions, it may indicate a potential hardware limitation. We understand that various tests have been conducted, including those involving an external display.
As a next step, we propose conducting a test with the latest drivers from the OEM or directly from Intel/Nvidia.
Here's the suggested procedure:
1. Connect an external display.
2. Utilize the display's gamma, overdrive, or shadow control settings (the specific names may vary by manufacturer) to fine-tune the image quality.
3. Perform this test on both GPUs. For Nvidia, running a game may yield more definitive results.
If an external screen test goes well, it means the graphics cards are working fine and the picture on the screen can be made to look right with a few tweaks.
Following this, we recommend that you contact your OEM to address the issue, potentially through a screen replacement or a control module repair.
Thank you so much for your understanding, and if you have any questions, please let me know.
Carmona A.
DiP43ck
Anfänger
6.676Aufrufe
External monitor working fine. There is some ghosting issue on different refresh rate but on monitor there are options to change response time (overdrive) and it works. So it looks like that there is no other way to fix it than send my laptop to repair service. Thank you for your help and time.
ACarmona_Intel
Mitarbeiter
6.652Aufrufe
Hello DiP43ck,
Thank you so much for the update.
As it appears that we have identified hardware as the cause of the problem, getting a screen replacement or control module repaired is your best course of action.
We hope that we were able to assist you in some way with your concern, even though that is the last recommendation that we can provide.
We sincerely appreciate your cooperation, time, and efforts during the investigation.
Bye for now, and best wishes to you.
Carmona A.
Antworten
