- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Disattiva notifiche
- Iscriversi a feed RSS
- Evidenziare
- Stampare
- Segnalare contenuto inappropriato
in this link https://www.intel.com/content/www/us/en/products/sku/230573/intel-core-i513600t-processor-24m-cache-up-to-4-80-ghz/specifications.html Max Turbo Frequency show 5.3Ghz but to Headline of this show up to 4.8Ghz in need to confirmation of this cpu the max turbo boost is 5.3Ghz or 4.8Ghz
Link copiato
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello yoyo5649,
Thank you for posting on the Intel® communities. I understand you would like to know the correct turbo frequency for your processor, it will be a pleasure to provide you with the information needed.
In this case, both frequencies are correct but apply to different features of your CPU. Bear in mind that Intel can only comment based on the information from the official Intel websites.
These frequencies are based on the maximum speed reached in a specific environment. 5.3 GHz is the "Max Turbo" Frequency is the maximum single-core frequency at which the processor is capable of operating using Intel® Turbo Boost Technology and, if present, Intel® Turbo Boost Max Technology 3.0 and Intel® Thermal Velocity Boost. Frequency is typically measured in gigahertz (GHz), or billion cycles per second, and 4.80 GHz is the maximum P-core turbo frequency derived from Intel® Turbo Boost Technology.
If you have any other, please don't hesitate to let me know.
Deivid A.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello yoyo5649,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello yoyo5649,
I was checking your thread and noticed that I have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
thank you so much for your answer. it make me clear about Max Turbo Frequency issue.
- Contrassegnare la discussione come nuova
- Contrassegnare la discussione come letta
- Sposta questo Discussione per l'utente corrente
- Preferito
- Iscriversi
- Pagina in versione di stampa
