12747 Discussions
HAL API for the Generic Serial Flash Interface FPGA IP, 'altera_safeclib'
meenalkb
In the user guide for the Generic Serial Flash Interface (GSFI) it says "altera_safeclib" must be enabled in the BSP editor to use the HAL API for this device.
With a Quartus 21.1 install and the accompanying NIOS II Software Build Tools for Eclipse I've searched through the BSP Editor UI and can't this setting at all. Also, when I generate the Eclipse BSP from my sopcinfo file, there are no HAL driver files generated for the GSFI.
Does anyone know how I can enable HAL support for this IP?
hareesh
Hi Meenalkb,
To enable the Generic Serial Flash Interface (GSFI) use the HAL API and follow the below steps in Eclipse.
  1. BSP Editor->Nios II
  2. file paths of .sopcinfo and .bsp (new or old) in the open BSP window and click on open.
  3. A platform design window will be open in which you select the BSP software packages option. In that, just enable the altera_safeclib option.
  4. Select Generate BSP.
once the BSP generation is completed. Check in the drivers->inc and drivers->src folders. for
https://www.intel.com/content/www/us/en/docs/programmable/683419/22-1-20-1-1/nios-ii-hal-driver.html
  • intel_generic_serial_flash_interface_top.h
  • intel_generic_serial_flash_interface_top.c
meenalkb
Also please un-mark as solved.
hareesh
hi
please share BSP editor version details, platform design screen shot and I am sharing the screen shot of that.
meenalkb
It was the same problem as what I described (community.intel.com/t5/Nios-II-Embedded-Design-Suite/HAL-API-for-the-Generic-Serial-Flash-Interface-FPGA-IP-altera/m-p/1393376#M51250). Can we arrange a call to discuss?
HAlex
Hello
Any updates with this issue?
I also have exactly the same problem.
Is it maybe because I am using Quartus Prime 21.1.0 Standard (and not a PRO) edition?
Thank you
Alex
meenalkb
Hi @HAlex
@hareesh has raised this issue as an internal ticket. I'm waiting for him to get back to me.
hareesh
hi meenalkb
 GSFI HAL API is only available in Pro. we are requested to Planner for this.
thanks,
hareesh
meenalkb
Could you please close this ticket now. Thanks
