12748 Discussions
How to save Nios II console contents.
In the NIOS EDS environment I need to save the contents of
the NIOS console which displays the output of the
printf statements. I have tried to copy from the window and
paste into another program but it does not work.
It is possible to redirect the window output to a file ?
Thanks in advance for the help
I'm not sure but I do this a lot from the command line by downloading my code using nios2-download -g -r <elf file> and then I fire up a terminal with nios2-terminal. If you have a board with multiple devices on the JTAG chain, or multiple Nios/UARTs, or cables then there are more arguments to pass in so check out the help commands for those two to figure that out.
If you want to dump the terminal to a file then it's just nios2-terminal >> my_file.txt which dumps the outputs to the file. >> is a standard linux command so you can google around to find out more about it.
I realize this is an old thread, but thought I would comment in case it is helpful for someone else.
If you want to copy from the Nios II Console and then past to a text editor , you can try this to see if it works...
save printf output from nios ii console:
• Currently using Eclipse from Quartus Prime 17.0. Not sure if this works in other versions.
• I have not found this documented anywhere, just found it by trial and error.
• Prior to clicking the run button, kill the Nios II Console window if it is open. It will re-open when it starts running.
• During/after run has executed, select text in Nios II Console window.
• Select Ctrl-Insert key combination. It should now be copied to the clipboard.
• Paste with Ctrl-v.
• This only seems to work once. Must kill window and re-run to do another copy/paste.
