12742 讨论
Need help changing from Eclipse Console to HyperTerm or Putty
名誉分销商 II
2,221 次查看
I have some SW running on NIOS II Stratix IV board on Eclipse. Now I want to use
a standalone Hyper-Terminal or Putty. I did it once in Xilinx, but now HyperTerm is
not available on Windows 7 and I don't know how to change from Eclipse console
to this other terminal. Where do I change the stdio, etc. Can someone help?:(
Shvitzer
0 项奖励
5 回复数
名誉分销商 II
1,385 次查看
You can change the stdin/stdout/stderr in the BSP Editor. Right click on your BSP, select "Nios II > BSP Editor...", Then you can select which device to send stdin/out to.
0 项奖励
名誉分销商 II
1,385 次查看
Thanks ! Have you used Putty or any other Terminal-Emulator this way? It has to be USB compatible though. I used Putty in the past but with an RS232 UART and COMx port.
I am not sure Putty is suitable for this. This will have to work in standalone more. I have no experience on this with Altera.
Cheers,
S.
0 项奖励
名誉分销商 II
1,385 次查看
In regards to the nios, I've only used the jtag uart/nios2-terminal. If you have a standard uart peripheral, attached to an rs232 chip, it should work with any standard terminal program, like putty or teraterm. I've used both putty and teraterm with USB to serial converters without issue in the past to connect to various serial devices.
Cheers
0 项奖励
名誉分销商 II
1,385 次查看
OK, the NIOS2 design is using only a jtag uart and the dev.board has only one USB connector. The PC also has only USB connectors so how do I mate the Tera Term to the USB connector on the PC and from there to the USB on the dev. board?
Can the Tera Term be configured to communicate via USB?
S.
0 项奖励
名誉分销商 II
1,385 次查看
Ahhh... if you're using the jtag uart, then I believe you're stuck with using Altera's nios2-terminal/EDS, unless someone else knows a fancy trick.
--- Quote Start ---
The JTAG UART core supports all Altera® device families. The JTAG UART core is
supported by the Nios II hardware abstraction layer (HAL) system library.
To view the character stream on the host PC, the JTAG UART core must be used in
conjunction with the JTAG terminal software provided by Altera. Nios II processor
users access the JTAG UART via the Nios II IDE or the nios2-terminal command-line
utility.
*http://www.altera.com.cn/literature/hb/nios2/n2cpu_nii51009.pdf
--- Quote End ---
0 项奖励
回复
