12745 Discussions
New application creation failure in NIOS II - Quartus20.1
VinayGB
I have installed Quartus 20.1 and followed instructions in n2sw_nii5v2gen2.pdf to install wsl2 and then Ubuntu and eclipse.
In eclipse workspace, when I try to create new application and bsp from template, following error message pops up
Failed to execute: wsl dos2unix create-this-bsp; ./create-this-bsp --cpu-name cpu_nios --no-make
Attached is the console prints when this error occurs.
Kindly support in creating new application and bsp in NIOS II - Quartus 20.1
I have tried all the solutions available in the community, like run as admin, changing between wsl1 and wsl2 and many more.
regards,
Vinay
MViss4
Note in 19.4 when opening an 'Nios II Command Shell (Quartus Prime Pro 19.4)' command shell and running 'nios2-bsp-create-settings' results in "nios2-bsp-create-settings: command not found".
However running 'nios2-bsp-create-settings.exe' (with .exe extension) does work.
In the Makefile there is some logic for this:
UNAME = $(shell uname -r)
ifeq ($(findstring Microsoft,$(UNAME)),Microsoft)
WINDOWS_EXE = .exe
endif
Refer to https://community.intel.com/t5/Nios-II-Embedded-Design-Suite/Error-s0-Error-during-execution-of-quot-C-intelfpga-20-1-quartus/td-p/1191914 as the uname is case dependent and only works for WSL1.
Probably your 'nios2-bsp-create-settings' is executed without '.exe' extension you can try to adapt the Makefile to use a hardcoded ".exe" extension
Eliath_G_Intel
Hi Vinay!
Thanks for reaching us.
I see that Mviss4 has already provided you a workaround,
I'd like to know if you have tried and if this solved your issue.
and please, share with me the OS you're using ( Windows or ubuntu) and also the Quartus version.
-Eliath
VinayGB
I am using Quartus 20.1 in Windows 10 OS.
I have installed-uninstalled-reinstalled wsl and ubuntu multiple times, but to same result.
I have not tried the work-around provided, as it is confusing. How do I adapt a makefile, if the project itself is not getting created ?
Kindly provide proper procedure to follow for creating new projcet and building it.
Please donot leave tool debugging to the users.
Kindly provide step-by-step approach of new application creation, building and debug/run.
regards,
Vinay
PS : Due to project timelines, I am forced to revert back to Quartus version 14 where Nios SBT works without any issues. Debugging NIOS SBT is not my job domain(although I had spent many days making it work). I had tried installing Quartus 20.1 and building same project in two different computers and every time I am getting new errors.
Mack
For me, I was able to fix this by editing nios2-bsp (in C:\intelFPGA_lite\20.1\nios2eds\sdk2\bin). There's a line that checks if you're running WSL:
uname=$(uname -r)
if [[ $uname =~ "Microsoft" ]]; then
_IS_WSL=1
windows_exe=.exe
fi
On line 37, it should be changed to:
if [[ $uname =~ "microsoft" ]]; then
This then causes the script to add .exe to the end of all the executables and a few other things that fixed it for me.
