16 bit sram timing question
QUARTUS 5.0 NIOS 5.0
I have problems with the timing of an sram chip on a custom board.
I don't know if it is some problem with reflections or something else.
i use ISSI IS61LV25616AL 256k x 16
NIOS [A18..A1] -> SRAM [A17..A0]
userlogic is setup as following:
Bus Interface Type: Avalon Memory Slave
PORT NAME | Width | Direction | Shared | Type
address | 18 | input | yes | address
write_n | 1 | input | yes | write_n
read_n | 1 | input | yes | read_n
writedata | 16 | inout | yes | data
chipselect_n | 1 | input | --- | chipselect_n
be_n | 2 | input | yes | byteenable_n
when I select timing in interface to userlogic and change "Wait"
e.g. Wait=2 it shown writen = 2cycles low, i think it should show 3
cycles low( one normal write cycle and two wait)
when i select:
setup=0 cycles
wait=0 cycles
hold=0 cycles
and check the timing with the scope for the following byte ,word and
dword accesses, then
- there are unnecessary read cycles in case of 8 and 16 bit read
- the dword 32 bit access has only one write strope and changes
address within strobe ?
the following show the timin g on the scope:
setup:0 wait:0 hold:0
(one X is 10ns)
BYTE(8bit) WRITE/READ (stb/ldbu)
CS XX__XXXX__XXXX__XXXX
WR XX__XXXXXXXXXXXXXXXX
RD XXXXXXXX__XXXX__XXXX
BE1 __XX____XX____XX____
BE0 ______________XX____
why second read access ?
WORD(16bit) WRITE/READ (sth/ldhu)
BE1 ______________XX____
DWORD(32bit) WRITE/READ (stw/ldw)
CS XX____XX__XXXX__XXXX
WR XX____XXXXXXXXXXXXXX
A0 ____XX________XX____
BE1 ____________________
BE0 ____________________
CS and WR are both low for 40ns ?
only one write access for two 16 bit words ?
is this timing normal ???
which documentation is actual up to date for avalon bus timing ?
additional question
C:\altera\kits\nios2\components
altera_nios_dev_kit_stratix_edition_sram2\class.ptf
contains
Hold_Time = "half_clock";
what does this means, how can I enter half a clock cycle in
the "Interface to User Logic" editor ?
thanks
